What is this Movement?
rustycolt
Please help! I bought this mantle clock sight unseen, and as it turns out, there are a couple of missing/damaged parts I need to replace. I am at a dead end trying to identify the movement however. To the best of my ability, I believe this is a Canadian made clock. The label inside the door does not have any names, but it appears to be identical in content and appearance to other clocks I've seen that were from the Blackforest Clock Co, which assembled cases and installed German movements circa 1920-40 or so, and was based in Toronto. I have stripped the movement, and the only markings present are the number 12, and 10653. Neither of these has opened any doors on my search. Attached are some photos of the movement and of the case.
I'm grateful for any leads this may generate.
JC
Hi  I have attached three lists of serial numbers from three german manufactuers who used serial numbers They may lead to somthing. With no makers mark It will only be identiiable by the serial No . style, clock pillars , not an easy task I wish you luck.
Gustav Becker Serial Numbers.html Herschede Serial Numbers.html Lenzkirch Serial Numbers.html
I forgot to mention that I read the Blackforest Clock Co was known to use Mauthe movements prior to WWII. I would expect to see a trademark stamp if this were the case. I haven't been able to find any Mauthe 8-day that resemble this assemblage though.
Watchweasol - thank you for those serial lists. From those we can eliminate Gustav Becker and Lenzkirch as possibilities. Herschede does have a match in 1922, so it warrants further investigation.
It is a Mauthe, it's not very common it strikes a melody on the half hour and the hour on the hour, the melody can be switched off and it will give a single strike on the half hour instead.
Yours has a wheel missing that transfers drive to the melody see pictures:1692954263_Inkedmissingwheel_LI.thumb.jpg.b4e8fef487af170d94f1ae5cbade55d0.jpg1791330486_Inkedmissingwheel2_LI.thumb.jpg.b113d8150a4b64f7472c7ac7a6fd52c7.jpg
Good eye [emoji1303] That missing wheel is the reason I’m trying to ID this.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
