Seiko 7s26 running at 30 000 bph
DOS0570
Hey there,
I have following Issue with my SKX007.
I have replaced the Balance assembley, and it seemed to rung nice. With low Beat error (0.1-0.2ms) and only a few second gain per Day.
But ever so often it jumps to run at between 28000-30000 bph. Losening the Balance Cock, moving it a bit and retightnig it most often solves the Case.
Is it just the Endstones that are dirty? Or may there be another Cause?
Thanks in advance
How long will it run at 28000 +? a few seconds?
How often does this occur? once a minute? once every 5 minutes?
Does this happen with the mainspring having a few turns of the ratchet wheel or with just minimal mainspring tension?
Anilv
Unfortunatly I wasn't able to reproduce it yet. Guess its a good thing.
When it occurs, it stays this way, until I manually loosing the balance Cock.
However after inspecting the Haispring again, I found a very small amount of corrosion. I scraped most of it away, and since then I haven't experienced the Issue again. Probably some of the corrosion fell off the spring and got stuck between the Cock and the spring, effectively shortening it.
Thank you for your Tips!
There could be many causes or contributing causes. But I have to agree with yankeedog on this one. If the beat changes dramatically and STAYED at that new speed, it is most likely a fowled hairspring. A drop of oil, perhaps? Mark demonstrated this on one of his videos.
I have experimented with a few different things to clean hairsprings.automotive brake cleaner is a mixed bag.one can will leave residue yielding a sticky hair spring.while the next can will not.results with CRC QD electronic cleaner have been pretty consistent.
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
    • Thanks guys.  quick question. For automatic movement, particularly this one. can I power down the main spring by pushing this rachet down?  i've gotten pretty used to SW210 and powering down a manual movement. But so far i've only been waiting for the auto movement to run out of juice before opening the case.
