Question, HS in the family
Question, Dr ranfft lists the entire family of each caliber. I wonder if the HS fitted on each member is of the same springness,width, thickness?    That is;  Providing the same beat and enough spring length, can the HS off of one be flown with the wheel of another member?
Thanks in advance.          Joe
11 hours ago, rogart63 said:
If the movement is different Hz i think they can have different HS . Been there with a  AS 1746. They come in different HZ versions . Didn't work and at first i could figure out why.
Correct, my experience shows HS of different frquencies are not interchangable even if flown with the wheel,  by the time you reach the right beat, you are left with a funny looking HS due to too much cutting.
In the past, like over 50 years ago, each spring was vibrated to its balance. Each balance, while superficially identical, could be different enough from the next one in the box to make the hairsprings incompatible. The modern method is more automatic, the springs are colleted then cut to a given length, the terminal curve formed, stud attached. They are then each tested and graded into about 20 categories; the balances are likewise graded into 20 categories. If you look at the results of the categorization, it makes a nice bell curve, with the majority falling within perhaps 4-5 middle spots, the rest dispersed in decreasing numbers towards the ends.
The balances and hairspring are just mated according to the category. If you try to mate a Cat 1 spring to a Cat 20 balance it won't work at all. If you try between Cat 9,10,11, it may work OK. Of course there's no way to know which one is which once it leaves the timing department of the factory.
Balances with screws add a dimension of adaptability as you can add and remove weight easily. Solid balances can only have weight removed, and the adjustment is permanent.
Edited by nickelsilver
Agree and you also have balance washers as well that can be added for weight, they have to be added evenly, if not the balance will be out of true.
9 minutes ago, vinn3 said:
  how do you remove weight accuratly from a "screwless balance"?   vin
With a very small drill on the underside of the rim. There are machines used in manufacturing that can very accurately determine the heavy spot and then very accurately remove material (the old machines used drill, the newer ones use a micro slitting saw). For the bench watchmaker how much to remove for poising is a matter of experience; the drill is usually held in a pinvice, and might be something like 0.20mm diameter.
Thank you Gentleman.
So, BW and HS on some vintage and I gather all antique time pieces, were to be (in pair ) vibrated to the design beat . Two BW on same assembly line were dynamically different even though they weighted and looked the same.
If a HS for a rare collectible pieces is needed, I think one can be extracted from other( not so collectibles) members of the family and true would then need to be vibrated with the BW anew.
I have been finding hairsprings in the family, that can be( cut) vibrated compatible with the BW at hand.
I hope to have made my question more clear to understand, which is , other than the length, are HS within a family the same?
If you mean the same CGS number (that is how they are classified), then yes, they should be the same.
I guess the name of  this metric system is adapted in horology, CGS;  Centemeter, Gram, Seconds.  Use of this term would have saved me a lot of strugling just to expalin a simple question.
Best Regards.       and thank you for the time you put in.
I guess you would have to depend on machines/ tools to remove the right amount of weight. Most basic tool should let you check for poise , easily.
Vintage hairsprings is probably the largest headache since most of the old knowledge has been forgotten when the modern watchmaker begun to buy balance complete with already matched spings and balances. The balance on these are laser adjusted.
On the packages of the vintage springs there often are the markings Gr and Fce learning what they stand for would help people like me with less knowledge to choose the correct spring to vibrate faster. Was there any standardized system for this type of marking?
@HSL  are these colleted?   I read some producers graded their products in like 4 or 6 classes by strength, like Gr4  stronger than Gr3.  One just chose the right class and had to collet, vibrate, curve the end, stud.
A bigger headache are uncolleted hairsprings, an extra unknown.
  • 3 months later...
Hi @nickelsilver  What is the name of the tool/instrument the colleted hairsprings are tested with?   I presume the coil strength is tested=measured to some degree of accuracy.
Happy Christmas .
Nucejoe- I don't know a specific name other than vibrating tool. Back in the days watch companies might have gad their own proprietary tools, Greiner made industrial level vibrating tools too, but the bulk of sprung balances come out of Nivarox and they have their own stuff.
For the bench watchmaker the "Luthy" tool is the standard, using a master balance. A member here is making an electronic master balance to fit these tools at a very reasonable cost which I intend to try out as soon as I can get around to ordering one.
Thank you for taking the time to explain.   Best wishes.  Joe
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
