Replacing a threaded stem and crown
Joshua
Hello, I discussed an Invicta watch with an NH35A movement a little while back. Upon doing my research it seems I need to replace the stem and crown, or at least the crown. Again, from my research it says I need to drill out the old threaded tube and replace the threaded tube with a new one that matches the new crown in question. My first question is how do I measure for the tube, I for the most part know how to measure for a crown, but I know there is a case side (the part that fits into the case) and an outside (the portion with the threading) diameter. Is just measuring the outside diameter sufficient in finding a suitable replacement and if not how do I measure the inside diameter because it seems it's in the case itself. Furthermore, do I use a drill bit that is the same size as the tube or do I use one that's slightly smaller? Second question is what drill and bits do you suggest getting preferably a set and what other tools will I need? If you guys could link me to them that would be wonderful. Lastly, will replacing the stem, crown and tube fix my problem of the stem and crown flipping the date as I'm unthreading it, details to the problem are in my original post.
Sorry for such a long post, but help would be highly appreciated.
-Josh
If the crown is damaged that is what you need to replace, not the tube.
Invicta doesn't like to give out parts and this is my project watch. I bought it so I could work on it. Would just buying a bunch of threaded crowns on ebay and hope one of them fits work? I honestly just want to know how to fix this. I've never dealt with threaded, only the standard push and pull.
They may not supply parts to individuals but not giving P/N is unheard even from the likes of Swatch group or rolex. Try with an authorized repairer or a seller that knows what  he is selling. Going buying at random, or adapting parts when the original is available is not a good approach. Also, in many cases damaged thread can be repaired.
Edited by jdm
So I just go look up an Invicta store near me and go there? Also, I'm pretty sure it's the crown. When I unthread it I dont even feel the pop, I have to manually pull it out more.
Nowaday everything is done online. As you describe it's not a problem with threads but the the crown spring perhaps. If you really want to do yourself you need to take it apart and examine all parts to understand how it works, and where exactly the fault is.
29 minutes ago, Joshua said:
I see, but regardless I need to replace the crown, so if I can't get an original from Invicta what do I do?
Research is the answer. You can find everything that anyone here can find, Joshua.  https://www.esslinger.com/watch-parts-screw-down-threaded-watch-crown/?gclid=Cj0KCQjwwb3rBRDrARIsALR3XeaiBsx7T3mtzIW32zvggp175aoZWdkdWaJl5pKPaPUVxhND9clt_ukaAnSQEALw_wcB
AND
https://www.ebay.com/itm/Original-INVICTA-Screw-Down-Watch-CROWN-7-5mm-Tap-10/163769860380?hash=item262171c11c:g:RSQAAOSw01pdI1m5:sc:USPSFirstClass!31721!US!-1
Edited by DavidMasters
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
    • Hi, I’m constantly asking my wife to help me with removing the stem in order to complete casing. To expand, this is not a challenge for me when the setting lever is secured by a screw (older calibers). However when the setting lever is attached to a spring loaded setting lever axel, like on more modern calibers, I simply don’t see how to apply enough pressure on the button to get the stem out short of putting the movement face down with the dial and hands attached, which I’m loath to do in order to avoid damaging the dial/hands? what technique should I be using? thanks
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
