70s Newmark Dive watch
Hello fellow enthusiasts!
I have a vintage newmark dive watch.
I really love the bezel and two crowns.
I would love love to get this baby back to it’s former glory. However, there a few issues preventing me.
Perhaps you guys / gals can help me.
The major issue is that the one piece of the stem locking system has sheared. I’m not sure what it’s called. The pin that stops the stem from pulling right out and when it should be working can be pulled and the mechanism shifts to wind. The peice that’s rests on the movement is fine, but someone has forced the stem out and snapped the pin that stops it.can anyone please advise.
Another issue is that the dial legs have also sheared off.
The rear back plate also doesn’t press down all the way and therefore there’s too much movement within the case for the movement.
The balance is also randomly stopping.
Please can have some advice.
Looks like an EB8805 -> https://17jewels.info/movements/e/eb/eb-8805/
It should be relatively easy to find a donor movement, as they were produced in large numbers.
I may in fact have one somewhere, but I'm at work, so I can't check at the moment.
What does the broken part actually do?
Do you have access to a 3d printer to print some sort of movementretaining ring? If not you may be able to modify one from a modern quartz watch to fit.
Edited by AndyHull
I presume, though the photos are unclear, that this is the jeweled version of the EB 8805, although that may not matter as I'm fairly sure the keyless work is the same on all versions, but I'll have a rummage when I get a chance and see if  I have that part in one of my donor jeweled EB 88XX movements.
Sourcing parts for these movements is generally a lot easier than with some of the higher quality stuff, simply because there were so many of them produced.
They do tend to suffer from a number of issues (in addition to the usual balance and fork problems).
The spring barrel is inclined to wear, and the strange hold down spring/bridge that keeps it in place is inclined to loose its springiness and allow things to slip. Also as you have found, the keyless work is a little fragile.
They produced a whole bunch of variants of this movement over the years, including a jump hour "digital" version - More info here -> http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&EB_8800
... and the service sheet is here ... -> https://www.watchrepairtalk.com/applications/core/interface/file/attachment.php?id=25537
Edited by AndyHull
2 minutes ago, AndyHull said:
I presume, though the photos are unclear, that this is the jeweled version of the EB 8805, although that may not matter as I'm fairly sure the keyless work is the same on all versions, but I'll have a rummage when I get a chance and see if  I have that pert in one of my donor jeweled EB 88XX movements.
I greatly appreciate all of your help!!!! A real asset to this forum.
I have had a scour through the internet to find donor movements, however i am struggling to find anything.
I would appreciate if your could have a look in your box of bits n' bobs and will pay you for one if you can find one.
Always a pleasure to help.
I'm at work, so I'll take a look later. If I have one I'll message you here on the forum and pop it in the post.
If you look at my previous post, I added a link to the service manual.
If you check that and give me the part number(s) then that will ensure I send the right bit(s).
Oh sorry didnt see the second URL.
I believe its item, 443/1 as its local to the other keyless works items.
For donor movements look on ETSY. Look at amystevensoriginals. The lady sells mainly to the art crowd . There are all kinds of movements which she sells in lots.you may have to buy five movements to get one screw.but her prices are reasonable.
Have you gentleman IDeed the caliber and the name or a picture of the parts?
I have an 18 liter bucket of parts and seriously doubt not having what all you need.
Please also give a full list of what you need to make it one sbipment.
Hi Andy, Not having checked my bag, I am sure I have got EB8800,  I got every part except the HS and possibly the fork. Do pins pallets break easily on those ?
Ryan speaks of other issues too, like random stop of the balance.
Only one post office appraises for customs charges in Shiraz and that is thirty km away from this side of town where I reside in, finding all faults and all he needs saves me multiple shipments.
I think same holds true for you as well.
Regards joe
8 hours ago, RyanGreerMcGilloway said:
WOW! Thank you very much! That's the exact movement.
It prevents the stem from getting pulled out and its also critical component for the keyless works.
And i dont have access to the 3d printer.
Its not an amazing watch but i like it.
Set lever?
Just out of interesst, what does that second crown do? I've seen some Newarks with a similar solution but they had a Ronda 1223 in them and the second crown wound the alarm. But is there an alarm on the 88XX?
3 minutes ago, RyanGreerMcGilloway said:
The second crown has no impact on the movement and only locks the rotation bezel in place
Ah ok thank you for the answer.
I found a 1223-21 in my treasure chest but no 8800 this far.
    • As an experiment i was thinking of not hardening it to see how it fairs. Now that i have a complete template i could knock up another in half the time if this loses its elasticity. I might play about with a few pieces today to test their bending and spring properties. This was cs 100 the supplier quoted in annealed state, it was nice to work with files so I'm taking it thats its state. What you are looking seems like it would need annealing to work it. This is why i went for this stuff that cuts out that process, it was so easy to work.
    • Showing state of hairspring on receipt, backplate & 'dished' wheel.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?       Have you seen this video, he shows how to determine where the indents go ?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
