Zodiac cal.76
Silvije
Hi guys,
I would like to clean the plexi from inside and also clean the dial from small dust particles on my newly acquired Zodiac Goldenline.
However, I have problems releasing the crown stem from the movement on that Zodiac cal.76 movement.
I have tried to push with the needle inside the hole located left from the stem but nothing happens. The stem is still locked.
I would appreciate any help with that.91ca62b6ac29e303ba1f590793a39fbe.jpg8cd50aff4e52cc243c23ddde7ad2f197.jpge5aaee81fc403df35217855780ee9cab.jpg
Poslano sa mog SM-A750FN koristeći Tapatalk
Hi guys. Still no progress but I think I found where the problem lies. There is one tiny screw north of the crown stem, which moves when I move the crown from 0 to 1st position and vice versa. Maybe it should be unscrewed slightly to release the stem.464867dff96a27ac0b93433e7f37ae39.jpg
You could also take a look at the parts breakdown of the closely related  Zodiac 68,70,72,74, 88 etc and the 76 from Cousins collection of PDFs.
https://www.cousinsuk.com/document/search?SearchString=zodiac
Similar content here ->
http://www.phfactor.net/wtf/Zodiac Parts/
Just for the record, lots of useful links to manuals can be found here ->
http://www.watchrepairinfo.com/techman.htm
Edited by AndyHull
Thanks Andy for many useful links. I will check them up.
On the Zodiac 76 you should have a set lever screw, turn it slighly while pulling the stem out should do the trick.
Thanks HSL. I think this will do the trick because this screw is moving in coordination with the stem action. Unscrewing it a bit should release the stem.
The most mechanical watches has either a screw you loosen to release the stem or you push on a pin directly attached to the setting lever. In this case there could be both so I had to look it up and the database says it has a set lever screw.
ZOD 76-75B 5443/1233 5443/ZOD 70 SET LEVER SCREW
Sometimes when they have a pushpin and the wear and tear together with rubberized oil makes it somewhat harder to get it pushed in far enough, then one gets a bit tempted to push a bit harder and voila' one have pushed it to far and the setting lever makes one unexpected liftoff. Mostly you recover from this since you had to service the movement anyhow.
Even the screws sometimes is a bit tricky but if one just gently push down at the same time one unwinds it the lever should be pushed down and release the stem.
The "Magic hole trick" usually can be found working on cheaper quartz movements where the lever is directly jointed with a plate,
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
