Battery change help
Hello all, I have just changed the battery on a cheap chronograph, it was working fine before, put the new battery in and nothing, put the old one back in and still nothing. I've read that on some you need to cross certain points to get them going again.
Now I've change batteries before but I think this is the 1st time I've done it on a chronograph.
The only marking on it is SL70 above the words No Jewels, like I said cheap! It's my youngest lads watch and he loves it.
Any ideas?03ac39a0a007eb34813d6dbf5a492746.jpga9c45852fe5c53d500119a933774c9c6.jpg
Sent from my SM-A405FN using Tapatalk
Hi  BS  By the look of the backplate which is featureless with only SL70 on it would look like an Hattori or a Chinese movment, also the fact that the plates are rivited to the frame, most likely plastic and there fore not for disassembly and is in fact a throw away movement, But having said all that if it was working before the battery change and has failed since I would check that you have not disturbed anything during the change. On some wartches   i.e. the seiko 732T it requires you to start the movment by shorting the ac point to the +ve terminal on the battery. There is nothing obvious in the pictures. Perhaps a clearer picture of the back plate and dial will render some clue. What name has it on the dial. removing the dial and hands might reveal a makers calibe number.
Also try pulling out the crown and resetting the hands to say 12 O'clock and pressing the crown home again, just to ensure everything actually turns, in case pushing the battery in has squished something.
Push and hold both buttons in together for 10 seconds and release. If that doesn't work, try the same thing with each button in turn.
Also check the voltage on the new battery with a multimeter as it may have been stored so long that has died of self discharge.
A new cell will be around 1.5V, or a little higher, and a dead one, probably under 1V.
Edited by AndyHull
Agreed generic China movement.as previously mentioned you may need to momentarily touch one point to another to start the watch.with the battery out you will notice a central contact which touches the positive side of the battery.follow the metal,see where it goes.look for a spot that would be exposed when the battery is reinserted. After you put the battery back in.Touch that spot  using a pin or tweezers or anything conductive  to the metal on the back of the movement . Additionally be aware that the watch stem is a switch.it must be pushed in.good luck mom.keep us posted.
Edited by yankeedog
Thanx everyone, I had tried practically everything mentioned, I didn't take the hands and dial off.
Anyway, the battery tested good, everything looked good and nothing seemed disturbed. So with nothing to lose, I figured it had just jammed or the plastic gears had stuck together when it had all stopped working when the battery was out. I've done this before and if it works it works, I got an old rotary quartz watch in my shed that's been running over 3yrs after doing this as a last resort.
I get the WD40 out! Spray some into the lid then with your finger dab the WD, give your finger a flick, then just touch the movement, on the gears, on anything that looks like it goes into the movement. Leave it an hour, if done right there shouldn't be anything that could be called excess, but give it a wipe and pop the battery back in.
This is the 4th maybe 5th time I've done this, and so far I'm 5 for 5! The watch is working perfectly again!
Well done,    one doesn't advocate putting wd 40 on watches, even quartz ones. Its better to remove battery hands and dial and cltane in Naptha (lighterfuel) or ISO propyl alchohol or even carburetter cleaner thyen when dry touch the pivots with quartz oil then a quick turn on the line release and in with battery usually they start up again. But full marks for getting it going again:Bravo:  Please dont do this on mechanical watches as wd 40 gumms the works up eventually and attracts dirt.
O god I'd never do it to a mechanical watch!
The reason I chose wd was for its penetrating and lubricating properties. I'm no watchmaker by any stretch of the imagination, I can swap a movement over, change a dial and hands, anything more than that and I'm out of my depth! I have a watchmaker I use for servicing and really the like. But if I run into a quartz watch that's given up I'll try what you suggest here.
Thanx everyone ;)
Quote
   there are penitrating oils available for metal.  after useing that,   wash the parts and add the proper viscosity OIL .  plastic parts - i don't  know,  may be silicon spray?   wd 40 - a waxy, oily spray,  good for ??      vin
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
    • Sirius. Thank you for helping others with that information. This is why this forum is so good.
    • Yes watchie , the indirect center seconds wheel. Also known as a sweep wheel remover.  If you zoom in to pullers you will see one plain bent puller and the other is split to bridge over one of the spokes. Cousins have been out of them for ages , they say the manufacturer for them for bergeon is no longer in business. Another company is supposed to be stepping in whenever that might be. The new ones dont look as well made as the vintage ones, but thats standard these days. I know you prefer the old swiss tools anyway.
