need service manule
vinn3
3 hours ago, Nucejoe said:
Valjoux 724 was produced for a short time and was replaced with 729 .
Manual of which would do, If you can find one.
Ni
   thanks;  that answers a few questions in my search.!  the first  is which screw holds the stem in.
To release the stem you loosen the lower one of the two screws by the stem.
I attache a service manual to the 72 but unfortunately with the wrong complication but in the 60's the tech sheets didn't always be the best.  ;)
If you need more help it's better to continue in an other thread.
Valjoux 72_88_721.pdf
Nivada:  The 30 mm mvt. is out of the case and stem "set in place".   you might notice,  i had to remove one of the levers to get a straight shot at the secont case screw.   i'll replace it and move on to cleaning.  vin
    steping back from a complicated mvmt. repair;  i opened  a 1950's west clock wrist watch.  German made case and US mvmt..  it has a very unique stem set lever.  one of the 4 scews holding the back plate holds a lever attached to the stem set pin.  vin.
33 minutes ago, Watchtime said:
Westclox was founded in 1885 In Illinois by Charles Stahlberg and wellknown for the Big Ben and Baby Ben alarm clocks...They also had a plant in Scotland...
    thanks. i've delt with" the bens"   years ago.  did not know of a wrist watch.  the alarm clocks are still sold in the U S , but,  they are bad,  half plastic  and the alarm off button is bad too.   its marked made in u.s.a..    i wounder?     vin
  • 2 months later...
    • Hi Vandan. Hi from a fellow newbie! Marshall has got a lot to answer for hasn't he! 😄. I also got hooked to this hobby after watching his videos.  Good luck with your journey to service your Grandfather's watch.   Nick
    • Hi all, I have a lovely Favre-Lueba dress watch from late 70s/early 80s in a stainless steel case.  Its an unusual curved rectangular case and crystal.  I'm wondering if there's any possibility I might be able to buy/find a replacement crystal for this watch.  The base of the crystal is also curved to match the case, rather than flat.  I'm looking at the Cousins website page here https://www.cousinsuk.com/product/rectsq-rounded-corners-one-side-curved-bezel-sternkreuz-rzr but not sure if I'm looking for the correct type.  In my case its a rectanglular crystal with rounded corners, and both the upper and lower surfaces of the crystal are curved.   Update - OK I now think I know what I'm looking for, but Cousins don't stock the size I need :-).  I think I need a Sternkruez RZ 315x220R9, acrylic, cylindrically domed with rounded corners.  Any tips or alternate sources for this source of crystal. Many thanks
    • Getting more interesting this post, innit? Mikeplilk, Waggy. Impressed with your efforts. Makes mine look amateurish. Hey, that's what I am. Still, I have good results with the 'frog'. Apprentice test piece. Paper is from https://www.ebay.co.uk/itm/234602659940?var=534248554534   I am aware that the more I delve into the DIY, the more I am gaining understanding of watchmaking. Well, a little each time. Ross
    • Now, that's a bad boy watch! 🫡
    • High frequency day: 36000 bph.
