Elma Watch Cleaning Machine
  • 5 weeks later...
  • 2 months later...
Hello, I’ve recently purchased Elma WP Pro watch cleaning solution from Cousins UK. I’ve not had chance to try it out yet but wondered what results any of you may have had with it, good or bad. I planned to use the volition in small sealed beakers / jam jars in my ultrasonic tank.
This will be the first ammoniated cleaner I’ve used, and so I’ll carry out the decanting of cleaner into the small jars in a well vented area, possibly out in my garage.
I’d be interested in hearing how you guys use the cleaner and the results you get.
Kind regards Deggsie
  • 5 months later...
Afternoon All, I hope you are all well!
I hope someone can help. Not so long ago I picked up an Elma Super Elite watch cleaning machine - alas without any jars. Is anyone aware of a cheaper alternative jar that can be used with the machine or will I have to purchase from Cousins or somewhere similar? (The one currently being sold by HS Walsh on eBay is a tad too expensive!)
  • 4 weeks later...
Hello everyone!
Looking for some advice on what kind of grease you would use for the maintenance of the machine itself.
I want to ensure the proper workings of the machine. I’d love to be able to take this thing completely apart but not sure where to even start.
Has anyone here ever serviced one of these before?
Any advice would be highly appreciated!
Latvas, I am new to this forum and just came across this post.  I have the exact machine for restoration (lots required) and am very interested in how you achieved such a great outcome, particularly the ID tags, Elma emblems/transfers/stickers and the timer dial. Were these still in good condition or did you have to restore these separately? Any help would be greatly appreciated.  Kind regards, John
PS The AUS Motor switch has three positions (AUS which makes the basket rotate clockwise; the centre position that stops the motor; and Motor which doesn't seem to do anything). Can you let me know what the three positions are actually supposed to do because I am not certain if it is currently wired correctly.
I also own the exact same machine: Elma Elite.
With this machine, the motor is moved to the fixed position of the jars.
This is different with Elma Record where the base does rotate the jars to the fixed position of the motor (like a carousel).
To my little knowledge, the motor in the Elite rotates the basket only in one direction. I think, the L&R cleaning machines have an alternating function - just as OldHippie describes.
This matches the switch on my machine: it‘s a toggle switch, that offers two positions: on and off - labeled as „Motor“ and „Aus“.
Hope, this might help.
Cheers
Thorsten
Gesendet von iPhone mit Tapatalk
Morning everyone.  I have followed the strip down procedures that some members have undertaken for restoring their Super Elite watch cleaning machine. They have been great. There have been a couple of comments about the difficulty in removing the shaft from the base unit. I am at that stage now.  To anyone who has done this, is there a trick to dismantling the shaft from the base?  If there is, I have not been able to work it out.
All assistance greatly received. Cheer, John
JAHM,
I believe your original switch has been replaced with a 3 - way switch which is connected to work as a simple 2 - way one. Might have been a lack of a proper switch when repaired. Those switches got cracked from time to time ;)
Thanks Rafau.  You are spot on. When I pulled most of it apart last weekend, there was an aftermarket 3 position switch in place with the lower portion not wired in. Obviously the original failed at some time in the past.
Looks like I'll be sourcing another one.  Cheers, John
  • 4 weeks later...
  • 5 weeks later...
    • All the best, family always comes first, and I believe you have made the right call that you mother deserves your full attention. However, when you need a little outside distraction the guys here will always be available for some banter or a heated discussion on lubrication 🤣.
    • Wire for what? if it's steel then only certain types of steel can be hardened ie high carbon steels: "Mild steel doesn't harden very well. It doesn't have enough carbon. Get something like O1, silver steel or if you want to go full watchmaker, then Sandvik 20AP". Source
    • I'm wondering if there's any specific type of wire I should get for hardening? I would assume it doesn't matter as long as the wire doesn't melt before it is at temp.
    • Thanks Michael, sorry you were affected by this terrible condition. It can happen to anyone, 50's is the starting territory for it. My mum has been telling me for decades, " if i lose my marbles then shoot me",  my standard reply for that has always been " dont worry mum i bought the shotgun years ago ".  The same goes for me, not being able to communicate or comprehend is a very lonely place, now known to me as Aphasia. My mum had no warning of arriving there, I've had my warning and it was my mum that gave it to me.
    • It's the hole in the mainplate that has become too big due to wear. I will try with some fine abrasive paper wrapped around a small file. I will start with 3000 grit and see what effect that has. Or I could try with a homemade burnisher. Anyway, I will post the result here soon.
