Rubbed in jewel hand tools
Seth
Hi there, Can anyone help me in obtaining a set of tools like Mark uses to open out the jewel setting and close over the metal after inserting the jewel in his video of Replacing a Balance cock jewel.I have searched every possible site that I can think of but no luck as yet so I thought I would try here.Regards,Trevor.
Tools for rubbed in jewels are not made anymore.
Your best bet is just to keep an eye on ebay, but don't bid unless they show good photos of the tips of the tools as they can be rusted or damaged and then they will be useless.
Remember you need both sets of tools, the openers and closers.
I've got a great set of openers, but still haven't got myself a good set of closers, you can get away without them if you have a watchmakers lathe, but that does get more compicated.
Good luck in your search.
Dave's Watch Parts has a set of openers/closers
http://www.daveswatchparts.com/JewelingTools.html
I've been doing this a couple of decades and lots of restoration on pre-1920s pieces, owned numerous sets of openers/closers, and never really liked any of them. In old stuff the brass or German silver seems to get brittle over time and doesn't like being stretched out and then back in. Cheaper grade watches respond better for some reason. In a really nice old Lecoultre or something I do it all in the lathe, sometimes making jewel holding bushings that are the same size as the oil sink (decorative one) on the bridge and it all blends in and is really invisible.
But they do work, those tools, sometimes.
Just did an Omega pocketwatch with separate hole and end stones in chatons American style, the rubbed in hole jewel was demolished and managed to press it out with the Horia, opened the lip a bit (in the lathe), and got a new one in. Re-rubbed with tweezers and you'd have to look really closely to see it's not original.
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
