Greasing barrel wall
AP1875
I've been following Marks course and I am now playing around with the mainspring winders.
I have a clone 3135 movement.
I have lubricated the spring with 8200 by running some foam contaminated with grease over the spring (like he shows). However, I am wondering do i need to put grease all around the barrel wall? I'm sure I've seen people doing this before but is not done in this video.
I only really work on the common automatic movements, do I use some grease 82xx to grease the wall of the barrel?
I have a link below to the website talking about lubrication of Rolex. Then I'm attaching a file that also talks about lubrication. So if it was a real Rolex you're supposed to use something called MR-1 that were never going to see in the real world. If you look at both references the mainspring itself is considered prelubricated only the barrel wall is lubricated with this strange substance.
I think if you do a search we've discussed barrel wall lubrication somewhere else in the message board. Another recommendation Is Kluber P125. But if you use this yet be really careful a is just a real tiny bit because it is super sticky
http://www.horologist.com/rolex_lubrication.htm
https://www.youtube.com/watch?v=7KNTrHVD088
https://www.cousinsuk.com/product/kluber-chronogrease-p125
Rolex-3135-tech.pdf
  • Thanks 2
That guy from Sawta is very talented, i follow his schools instagram page, he comes across as a menacing genius. My other takeaway from that video is the practical aspect of greasing the barrel wall. Looks like you need a lot of grease and i imagine when you put your winder in it goes over the edges... I noticed in other threads you talk about 8217, unfortunately the links are broken. I have this grease, would this be an acceptable alternative to the p125? I'll post a picture when i've greased a barrel wall just to check i'm doing it correctly.
I presume Mark doesn't grease the barrel wall of the movement in the video due to it being a manual wind.
You want to be very careful on assuming that all lubrication's function exactly the same and the quantities used are exactly the same. As shown in the video if you're using Rolex MR-1 You use what looks like an excessively huge quantity. But if you're using Kluber P125 And you do the same thing you're going to regret it as this stuff is super sticky. Then I have a link below there is additional lubrication's such as you mentioned the 8217 and 8212 for aluminum Wall barrels and 8213 for brass wall barrels.
So basically each of the automatic lubrication for the barrel walls mentioned above is different. That means the quantities applied are different their characteristics conceivably different which is typical for horological lubrication it adds to the confusion.
Then manual wind watches have their mainsprings attached the barrel wall they do not require breaking grease. Automatic watches require their mainsprings to slip before the watches wound up tight. Otherwise you may break the automatic winding mechanism or if you get enough pressure on the mainspring it can cause timing issues with much power. So the mainspring has to slip before the watch is wound up and it shouldn't slip prematurely or too late.
 It looks like from the description below 8217 is a general-purpose soft breaking grease. So basically it looks like a general-purpose breaking grease probably not as sticky asKluber P125 So conceivably use a greater quantity of it. But probably not as much is the Rolex grease.
http://www.moebius-lubricants.ch/en/products/greases
As far as I know Rolex developed a special grease for the barrel wall called Tepa. This is only availiable for certified dealers (so not for me). So when I had to lubricate the barrel wall of my 16600 sea dweller I used 8217. It works, watch runs great at about 300 amplitude. Of course I don‘t know if this will be the same on an clone.
Please excuse the off topic, these are called clones as an euphemism but counterfeit is the proper term especially when there are falsified markings. They are, of course, very far away under all aspects from the authentic item.
As shown by our Host Mark Lovick
Edited by jdm
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
