Sharpening pegwood etc.
Klassiker
I'm looking for tips on how to get a really sharp point on pegwood etc. I've tried a pencil sharpener, which just puts a long, thin tip on the wood, without bringing it to a point. I've also tried a scalpel, but I don't like the facets and edges leading up to the point. I want it nice and round if possible. I know it's possible. I even saw a perfect example in a post I read recently (poss. from Nickelsilver). So what do others do? Use a file, or abrasive paper? I tried this too, but I still never got a point sharp enough to clean jewel holes for example.
I use a cutter knife, the kind with replaceable blades that break off in like 10 little sections. Facets are good!- they help clean. If you're doing jewel holes you need to resharpen after each one, you'll get quick fast. I use a loupe. I also do a lot of small watches with 0.07mm jewel holes...
2 hours ago, oldhippy said:
I just used a sharp pen knife. I also used cocktail sticks.
OK, seems like  the experts use knives. Do you actually cut, or scrape? What kind of angle are you trying for at the tip? Do you need to clean the dust, fibres or flakes away after sharpening, and if so, how?
I use both "cocktail sticks" (got to love the British sense of propriety) and peg wood.  Use a disposable scalpel and "whittle" the point.  When I'm getting close to a point, I simply cut less and less by reducing the angle of the blade to the stick.  Use your magnification to look at your work.  And yes, repeat the pointing exercise between each jewel unless you move to one with a bigger central hole.
Good Luck,
RMD
Edited by rduckwor
typos
For general just pushing and holding I cut a steeper angle maybe 30 degrees, for fine pegging of jewels a shallower angle of 15-20 degrees. Cut, not scrape. I find that pegwood is faaaaar better for fine work than toothpics or bamboo skewers or whatever. For clocks I do use lots of toothpics.
Like others I just use a knife.
I have a small quality 2 bladed Barlow pocket knife I've had for so long I don't even remember how I got it.
I have the small blade sharpened nicely and just use that.
I try to keep it evenly sharpened on all sides, but as said above facets are good, they help remove any dirt.
I have a large amount of pegwood of many sizes so I have never used anything but pegwood, so cant tell you if it is better than kebab sticks or toothpicks, or any of the other alternatives, but pegwood is cheap and lasts ages so I see no need to try something cheaper.
Tony
  • 2 months later...
I wanted to pick up on this again, as I'm still not satisfied with the results I'm getting. Here are some pictures:
WIN_20191103_18_55_21_Pro.jpg.0ab8bf192c93c9d5c29424adf29792ea.jpgWIN_20191103_18_57_31_Pro.jpg.ef782810a4bd7c6091e1afb21963cdb4.jpg
That is really the best I can do with a freshly sharpened scalpel blade and the 3mm dia. pegwood I have. I don't think the point is sharp enough or long and thin enough to really get in the hole and clean it. Also, I'm worried about the tip breaking off in the hole. A flake dropped of while I was taking the first photo. You can see it at 7 o'clock.
I read in another thread that there are different qualities of pegwood. Is that my problem, or am I just not cutting it with the knife?
My dog sheds loads of sturdy bristles. I am seriously considering using them instead.
You can also try sharpening a toothpick harder wood, no flakes. However, I always use peg wood.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
