Sharpening pegwood etc.
Klassiker
I'm looking for tips on how to get a really sharp point on pegwood etc. I've tried a pencil sharpener, which just puts a long, thin tip on the wood, without bringing it to a point. I've also tried a scalpel, but I don't like the facets and edges leading up to the point. I want it nice and round if possible. I know it's possible. I even saw a perfect example in a post I read recently (poss. from Nickelsilver). So what do others do? Use a file, or abrasive paper? I tried this too, but I still never got a point sharp enough to clean jewel holes for example.
I use a cutter knife, the kind with replaceable blades that break off in like 10 little sections. Facets are good!- they help clean. If you're doing jewel holes you need to resharpen after each one, you'll get quick fast. I use a loupe. I also do a lot of small watches with 0.07mm jewel holes...
2 hours ago, oldhippy said:
I just used a sharp pen knife. I also used cocktail sticks.
OK, seems like  the experts use knives. Do you actually cut, or scrape? What kind of angle are you trying for at the tip? Do you need to clean the dust, fibres or flakes away after sharpening, and if so, how?
I use both "cocktail sticks" (got to love the British sense of propriety) and peg wood.  Use a disposable scalpel and "whittle" the point.  When I'm getting close to a point, I simply cut less and less by reducing the angle of the blade to the stick.  Use your magnification to look at your work.  And yes, repeat the pointing exercise between each jewel unless you move to one with a bigger central hole.
Good Luck,
RMD
Edited by rduckwor
typos
For general just pushing and holding I cut a steeper angle maybe 30 degrees, for fine pegging of jewels a shallower angle of 15-20 degrees. Cut, not scrape. I find that pegwood is faaaaar better for fine work than toothpics or bamboo skewers or whatever. For clocks I do use lots of toothpics.
Like others I just use a knife.
I have a small quality 2 bladed Barlow pocket knife I've had for so long I don't even remember how I got it.
I have the small blade sharpened nicely and just use that.
I try to keep it evenly sharpened on all sides, but as said above facets are good, they help remove any dirt.
I have a large amount of pegwood of many sizes so I have never used anything but pegwood, so cant tell you if it is better than kebab sticks or toothpicks, or any of the other alternatives, but pegwood is cheap and lasts ages so I see no need to try something cheaper.
Tony
  • 2 months later...
I wanted to pick up on this again, as I'm still not satisfied with the results I'm getting. Here are some pictures:
WIN_20191103_18_55_21_Pro.jpg.0ab8bf192c93c9d5c29424adf29792ea.jpgWIN_20191103_18_57_31_Pro.jpg.ef782810a4bd7c6091e1afb21963cdb4.jpg
That is really the best I can do with a freshly sharpened scalpel blade and the 3mm dia. pegwood I have. I don't think the point is sharp enough or long and thin enough to really get in the hole and clean it. Also, I'm worried about the tip breaking off in the hole. A flake dropped of while I was taking the first photo. You can see it at 7 o'clock.
I read in another thread that there are different qualities of pegwood. Is that my problem, or am I just not cutting it with the knife?
My dog sheds loads of sturdy bristles. I am seriously considering using them instead.
You can also try sharpening a toothpick harder wood, no flakes. However, I always use peg wood.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
