Strange behavior of a Rolex 1575
I recently serviced a Rolex 1575. Everything demagnetized, clean and oiled. Finally I did some rounds of dynamic poising and got to this point:
Dial up: 305°, +2 sec
Crown up: 265°, 0 sec (I'm wearing the watch on the right wrist, so crown up is important to me)
Crown left: 265°, +2 sec
24 hours later I found this:
Dial up: 305°, +9 sec
Crown up: 265°, +7 sec
Crown left: 265°, +9 sec
I don't get it. Amplitude didn't change, poise errors as before, but a faster running watch. Of course I will correct this, but I'm curious and want to understand what has happened here. Any Ideas?
Congrats on those great results! However, I'm afraid I have no idea why you get the different rate 24h later. After a service, and if possible, I always try to wear the watch for a couple of days or so before I try to regulate it. I believe the lubrication of the watch needs to be somewhat evenly distributed before regulating. I saw an enlightening article about it here.
Wait, that's after 24 hours of running without winding, or after 24 hours, then wound up again? I would not expect the amplitude to be that high after 24 hours. As for the rate, in my experience that can shift easily as much as you have seen after a service. I usually let a watch run for at least a couple of days before doing final timing. Some calibers are worse than others!
Rolex 1575 is an automatic. It should not make a difference about how much power you have running through the movement. Did you use the correct oils, you might have used to much or to little. You need to let it settle down and then test, that will give a good average of the movements performance
Thanks for the answers. A more detailed description first:
I reassembled, oiled the pallets with 941 and let the watch run for 48 hours dial up.
Then I did the poising and after a full wind the first measurement on the timegrapher with result +2/0/+2.
Then I wore the watch (normal day in the company) for 24 h. Then after a full wind second measurement with result +9/+7/+9.
So maybe the mistake was to let the watch run static in dial up position instead of "shaking" it while wearing? Or the period of 48 hours was too short? Right now the watch is on my wrist and I am observing the "real" gain compared to the atomic clock.
5 minutes ago, oldhippy said:
You say a full wind. Isn't it an auto, Or do you mean one turn of the button. You know you cannot wind an auto fully up.
At assembly complete the mov't is fully wound at the ratchet screw. That fully winds automatics, and an automatic arm, or a  winder box does as well.
You cannot fully wind up an auto. that is why the mainspring has a slipping device. The spring will only wind so far before the action takes place.
No disrespect but I don't agree with what you say. When in good working order an automatic can be wound to its designed full capacity to provide the specified power reserve. I call this fully wind.
Then if the same barrel could be wound more for a small fraction of turn if the mainspring was to be hooked to the barrel is irrelevant. An automatic barrel is not designed or specified to work like that.
Edited by jdm
See how long it take you to wind an auto up using the button. You will give up because your arms and fingers will ache.
Well, since you mentioned. I work mainly with Seiko, the 6R15 fully winds to 50 hrs power reserve with about 40 crown turns. The 4R36 has 42 nominal hours and it could take a bit less, I should check.
Sorry again for the thread hijack.
34 minutes ago, oldhippy said:
I didn't think Seiko automatic movements wind up from the button?
It depends on the mov't. 7S26 and its direct predecessors don't. All the others do and you might be surprised to learn that they hack also.
Well, I don't know the official terms because I'm only an amateur. What I meant saying "full wind" on the 1575 (which is of course an automatic) is: I turned the crown about 40 revolutions so that I'm absolutely sure the mainspring is in the "slipping area". Thats "full wind of an automatic" for me.
Status update: After 30 hours the watch is 11 seconds ahead of the atomic clock. So the "about +9 result" of the timegrapher seems to make sense. I will observe until sunday evening if this is continuing.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
