Sekio 6119c
Hello i am trying for the love of God to repair a 6119c,  I bought another movement for spares, I have watched a number of videos on some one else dismantling and reassembling the same movements. I used an ultrasonic like i do with any other movement and cleaned them both up,  I put it back together  and then the day wheel disc and the date dial, once i put the dial on, they seem to sit 1/2 off each other.    any ideas or feed back would be good.
Be sure that the date jumper sits between the date wheel teeth and the date wheel is flat before installing the date guard. You can check if it is with the guard installed. Also be sure that the day wheel spring (that is part of the date guard) is also between the teeth of the star behind the day wheel inspecting through the visors on the day wheel.
Are you using the original day wheel for your watch? These wheels are different depending on the possition of the crown, you cannot use a day wheel made for a 3 o'clock crown watch on a watch with the crown at 4 o'clock, because the text won't align with the day window on the dial.
Thank you aac58, I was thinking if the spare 6119 was a 3 o'clock set or 4, once again I will go through the steps and have a look at the date wheel. thanks for your input. I was told that the 3 o'clock set is not as common as the 4 o'clock set. i checked the dial guard to ensure they were the same.
2 hours ago, Francisdownunder said:
I now have a Seiko Sportmatic Seahorse that I want to repair but can not seem to find any manuals on the 2451 movement. the site I go-to for most of all doesn't have the movement listed, anyone else know of other sites that may have something?
Part list found via Google attached. When service sheet isn't available just proceed as with a similar mov't, take plenty pics, separate different screws and it won't be a big deal as long one know why he's doing.
2451,6601A.pdf
Edited by jdm
Here you have a walkthrough of a 2451 (Seiko Silverwave diver from 1964) and a 6601 (1964 and all that: Part II) which I think it's about the same thing according to the part list. Maybe they are not very detailed in every step, but may help you.
https://adventuresinamateurwatchfettling.com/category/seiko/6601/
Edited by aac58
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
