Pocket Watch Identification
Hi Everyone,
New to this. Have a pocket watch as seen in the pictures. I've stripped it down so far. I have done a bit of quick learning by researching it. I believe it is turn of the century. All parts are serial numbered the same 12796. It's not a fusee but not sure if it is a "going" or "motor" barrel. The mainspring may be a T End and I am still working out size needed.
From the pics is there a diagram somewhere for parts? Is this an English watch or is it one of the turn of the century mass imported American one?
I believe it was sold by a "watchmaker" R. Richardson who may have only been a seller. The case is silver and hallmarked as shown possibly 1895? The case maker I believe is C.H possibly Charles Horner. Who is the watchmaker is the big question.
Whats parts are missing?
Any help would be great as I am itching to put it all back together again. I will need some hands for the dial as well, if anyone can advise it would be appreciated.
There are also inscribed numbers on this inside of the case, servicing references maybe?
Thanks.
Welcome, 99.
the only thing I see missing is the mainspring, a couple of screws and possibly a cannon pinion.  Can’t tell from the pics.
the hand written markings are most likely service marks. The stamped markings will guide you to some more info about the case.  I can’t tell if the case has the same serial number.
Thanks ITProDad,
The case and all the larger brass bits of the watch movement all have the same serial number 12796 although the one part of the case has the 1 and 2 stamped 2 and 1. The stamper possibly picked up the wrong stamp LOL. Hallmarked Chester UK and year O which I believe is 1897 ish. But it's not an Elgin, or a Waltham.
Could it be a Ball Hamilton http://www.pocketwatchrepair.com/histories/ball.html  from 1897 sent to England?
I am not a pocket watch expert but in lieu of someone with better knowledge posting a reply I can at least make some hopefully useful comments...
The three wheat sheafs and sword symbol on the case tie this to the Chester assay office which, with the letter 'O' date this to 1897.
Whilst I can't identify the movement maker for you I don't believe your steer towards Elgin is correct. The layout of the movement you've found doesn't match but also realise this was a US maker and your pocket watch seems very 'English' if we consider all the markings. Also crucially note that the escapement design is the English Lever type.
As a suggestion use the google image search facility and see if any of the above gets you any closer with relevant search terms e.g. english lever 1897.
    • Instead of using tweezers, put a piece of rodico onto a toothpick or pegwood. Then set your spring to the rodico, this way the spring is not under any tension when floating it back into the bloc. As you bump into the bloc when trying to find the entrance the rodico will give but still holds onto the spring ie. You wont have the rigidity of tweezers.
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
