Looking for a camera
I am looking for a camera with a macro function to photograph my work.  I had a 18 or 20 megapixel Sony point and shoot that worked great for super close pics, but lost it in a fire.  Dont remember the model but it was a pocket sized camera I could zoom and focus on pallet stones with excellent definition.   It was less than $200 US.   Now I can’t find a camera that will do the job for less than $500  Any suggestions?
Mark uses Panasonic micro four thirds  (as I do, but Olympus), and then switched to Canon full frame I think.
My personal finding is that stands and lighting are far more important than camera and lenses. For the latest and better I suggest  you browse dpreview.com
I agree with this, a good lighting makes wounders.
Usually when I post here I take a quick picture with my phone and the 21Mp is quite fair and the files are small enough to upload.
But a camera, correct lighting and a macro is what it takes to do some good movement por*.
This pictures is just a part of a picture since I can't upload the complete one (Camera is a Sony A7R II 42,4 Mp so the files  becomes large) but one gets what the difference in ligting do compared to my phone ones, this is just a part of the picture, it is just over 800k large! (or small).....
Well I was actually about to compare two cameras just to show how much improvement one can get with a good lighting but for some reason I just can't find the second camera a much cheaper SONY A37Y with macro lens too but for a fraction of the price.
Guess I will not do that after all  :(
There is a lens addon that allows a normal lens to be used as a macro lens, you just need to know what is the thread size of the outer ring. This would probably not work on point and shoot cameras though. Its pretty cheap too, I think I paid around $25 for the one I have but I dont remember where I got it from.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
