Looking for a camera
I am looking for a camera with a macro function to photograph my work.  I had a 18 or 20 megapixel Sony point and shoot that worked great for super close pics, but lost it in a fire.  Dont remember the model but it was a pocket sized camera I could zoom and focus on pallet stones with excellent definition.   It was less than $200 US.   Now I can’t find a camera that will do the job for less than $500  Any suggestions?
Mark uses Panasonic micro four thirds  (as I do, but Olympus), and then switched to Canon full frame I think.
My personal finding is that stands and lighting are far more important than camera and lenses. For the latest and better I suggest  you browse dpreview.com
I agree with this, a good lighting makes wounders.
Usually when I post here I take a quick picture with my phone and the 21Mp is quite fair and the files are small enough to upload.
But a camera, correct lighting and a macro is what it takes to do some good movement por*.
This pictures is just a part of a picture since I can't upload the complete one (Camera is a Sony A7R II 42,4 Mp so the files  becomes large) but one gets what the difference in ligting do compared to my phone ones, this is just a part of the picture, it is just over 800k large! (or small).....
Well I was actually about to compare two cameras just to show how much improvement one can get with a good lighting but for some reason I just can't find the second camera a much cheaper SONY A37Y with macro lens too but for a fraction of the price.
Guess I will not do that after all  :(
There is a lens addon that allows a normal lens to be used as a macro lens, you just need to know what is the thread size of the outer ring. This would probably not work on point and shoot cameras though. Its pretty cheap too, I think I paid around $25 for the one I have but I dont remember where I got it from.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Hi Frank, you have dived headlong into the deep end. Hairspring work has to be the scariest thing a newbie has to tackle. Your hairspring appears to be bent and just putting it back into the regulator would not allow the balance to work properly. It might start oscillating but the performance would not be good. The proper thing to do is to unstud the hairspring, remove the hairspring from the balance, reinstall the hairspring on the stud carrier, reshape the endcurve and centre the collet to the balance jewel hole. This challenge would either make you or break you. Hope that you will be able to fix your watch. Welcome to the world of watchmaking.  Watch this video. It think it'll give you an idea of the task ahead. From your 1st photo, I think you have a etachron type stud. Let me see if I can find a video on how to remove it from the arm.
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
