  • Similar Content
    • By DouglasSkinner
      I have an old Waltham pocket watch movement which is missing the impulse pin (roller jewel).  I have a limited number of actual jewels and since this is just a practice movement I thought I'd try to make one out of brass.  I've seen this several times in old pieces--usually a very sloppy job.  So I got some brass stock of the same diameter as the "D" in the roller table, filed it and burnished it to a high gloss.  Then I took a small, very fine diamond file and filed it half flat to form the "D"  I then polished the face using progressively finer sandpaper on a steel block.  This works fine--so far!  Problem is separation of the piece from the stock.  Again I used a small cutting file to do this but it doesn't leave the end very pretty.  So what I've done so far is to fit the good end into the roller table.  I then plan to shellac it in place and see if I can very carefully adjust the length and clean up the end.  Has anyone done this before?  Any suggestions as to how best to do it?
    • By arkobugg
      Cheers mates!!
      Had to get new winding stem to an Omega cal. 342 , beacuse not original crown.
      Got an replacement from Ronda, but does not fit.
      Tried to fit the stem yesterday, but Im not able to get in in right in the movment.   The original just go right in every time, but the new Ronda stem will not go properly in.   Are there anyone that have some ide why this not fit?   Can the notch in the stem where I have put red arrow have somthing todo with this??   Its slightly smaller on the Ronda stem...  se photo
    • By arkobugg
      Cheers Mates!
      Working on a Omega Cal. 613, have done service, and watch performs well on the time-grapher, but when put dial and hand on, I can see that the
    • By Harmines
      Hello all
      i wonder if anyone could offer some advice. I have an Omega seamaster 1345 quartz day date. Working well. However it seems the date is stuck (as shown in pictures) i know the push button at the 4 o clock position is meant to filter through the date? However when pushed in nothing seems to happen. As a result of this the watch works fine but only up untill 11pm it doesnt turn over to midnight and therefor change the day or date. Minute hand works perfectly but it seems i have to change the hour position every morning.
      when i turn the crown, hour hand moves fune and after the 12 o clock position changes the day, but date does not moth along with it.
      anyone know how i can resolve this safely without removing too many parts of the movement?
      Many thanks
    • are we talking about round wylers?  the special crystols are hard to find. there were several colors.     vin
    • I'm going to have to do something. One decent desk lamp and bulbs high up in the ceiling are not enough for me.
    • You are most welcome.
    • Thats  a poser,  what I had fitted to the bench at on time was a four in line which used halogen bulbs the same thing uses LEDs now and fitting that up with some 2by1 and made colapsible so that it folds up. the multiple light array should go some way to removing the shadows as the lights strike at different angles,  if it has a decent base a G clamp will fix it to the table/bench, food for  thought.
    • Yes, something like that might do the job. In many ways similar to the goose neck lamp I’m looking at. If only I knew what I need. The light in the picture I posted is very good (not the small one), it’s the fact that it is slightly in front of me hence the shadows. I can move it right above what I’m working on, but again, there will be shadows elsewhere because my hand and head will get in the way. I’m starting to think that a floor lamp next or close to me will be the best solution, casting the light from opposite direction. A head torch would be perfect but I don’t want to sit there with it on for hours. When I look at Mark’s oiling videos (jewels) it’s so clear, yes it’s a lot more magnified than my 12x loupe but there are no dark areas.
