  • Similar Content
    • By east3rn
      Hello.
      I am about to work on a Omega ladies automatic watch.
      I found out that the axis of the rotor is out of place and shakes up and down.
      What could be done in this situation?
      Thanks!
    • By DouglasSkinner
      I have an old Waltham pocket watch movement which is missing the impulse pin (roller jewel).  I have a limited number of actual jewels and since this is just a practice movement I thought I'd try to make one out of brass.  I've seen this several times in old pieces--usually a very sloppy job.  So I got some brass stock of the same diameter as the "D" in the roller table, filed it and burnished it to a high gloss.  Then I took a small, very fine diamond file and filed it half flat to form the "D"  I then polished the face using progressively finer sandpaper on a steel block.  This works fine--so far!  Problem is separation of the piece from the stock.  Again I used a small cutting file to do this but it doesn't leave the end very pretty.  So what I've done so far is to fit the good end into the roller table.  I then plan to shellac it in place and see if I can very carefully adjust the length and clean up the end.  Has anyone done this before?  Any suggestions as to how best to do it?
    • By arkobugg
      Cheers mates!!
      Had to get new winding stem to an Omega cal. 342 , beacuse not original crown.
      Got an replacement from Ronda, but does not fit.
      Tried to fit the stem yesterday, but Im not able to get in in right in the movment.   The original just go right in every time, but the new Ronda stem will not go properly in.   Are there anyone that have some ide why this not fit?   Can the notch in the stem where I have put red arrow have somthing todo with this??   Its slightly smaller on the Ronda stem...  se photo
    • By arkobugg
      Cheers Mates!
      Working on a Omega Cal. 613, have done service, and watch performs well on the time-grapher, but when put dial and hand on, I can see that the
    • You got any naked pictures of it, Yank? I didn't remember MW selling a house brand watch.  70's from the style I'd guess.
    • A once great American  retailer. Montgomery (monkey) Ward sold watches  under  the legant  lable.This Hamazawa powered version  came with a bad mainspring. After  cleaning  lubing swapping. this example  runs surprisingly  well. Don't turn up your  nose  at a 17 jewel Hamazawa. They  are better  than you might  think.
    • Digital  watches  are great provided  you can read the numbers!
    • My advice would be to spend most of that for tools. You already have the stero microscope to see very closely. Taking super high res picture would not fix faults and to get advice on the forum all you need is a regular macro camera even if few years old. Bust surely you need a stand.
    • yer i only want to spend about £400. And no i don,t have a camera as yet.
