Citize Watch Templates?
stevew
  • 4 weeks later...
It is Adobe illustrator, i have not got round to making the transfer yet. Need to get some silvering powder to do the dial first. Might be a while as few personal problems. Was my first attempt. Illustrator is good being vector based, making the sizing of letters easier. Must look at inkscape too. Useful for hard to find replacements, and as not expensive Watch it does not matter. Maybe we could start a trend with others doing same.
When finally get to do the dial will post outcome, but as said may be a while.
I have printed a few dials with fair results using Microsoft  paint. Nothing impressive  to say the least. Downloaded images, doctored a little  to suit my taste. Legible, but nothing  to crow about. This technique  looks  promising.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
