Can i use lubeta v106 for
  • oldhippy changed the title to Can i use lubeta v106 for
Yes you can. It is for reverse wheels.
thank you. CousinUK recommends using lubeta V105 for reversing wheels. And Lubeta V106 for bearings. But I only bought Lubeta V106. Using V106 for reversing wheels is still as good as V105? Excuse me if the spelling is not good. I use Google translate.
I had a bottle of Lubeta V106 . Can't say i use it a lot. So when i open the bottle it was dry. Had closed as hard as i could . My experience say  9010 diluted in naptha is as good as Lubeta V106.  If you don't use it every day.  It's evoporates very fast  so gets thicker as times go by.
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
