Introduction
Silvije
Hi guys,
I am not new to the watch hobby (6 years already) but I am almost completely fresh into watch repair hobby.
I am looking forward to reading the posts about it, to ask the questions and finally to give the answers in this community.
I am 30 year old tax consultant, living in Zagreb, Croatia. In my free time I am, aside from watches, running marathons and climbing whenever I can. :)
Best regards
Silvije
Hello All,
I've had access to the lessons now since this past December  I thought I would finally say hello! My name is Jason and live in North Dakota USA. I have a serious watch and watch repair bug. I am still very much a novice and still do not feel comfortable servicing any of my watches as of yet. In fact I am still disassembling and reassembling the Unitas 6497. I have done this only 4 times now. Not very many watchmakers in ND and believe there are only 2 in the entire state that do it professionally. 1 that I frequently speak with who is a bone fide CW21 located in Fargo informed me that the Units 6497 was the exact movement he learned on. Said tear it down and put it back together until you can do it blind folded. So that is what I am doing!I truly hope I get to know you all!
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
