KIF 6-1 Shock spring - help needed
Shock spring KIF 6-1 has gone awal after coming loose when servicing Bulova Cal 5BD.  This is the smallest KIF Ultraflex (overall length is 1.60mm) and is indicated as obsolete at Cousins (my normal source), and no luck with web search.
Can anyone help with another supplier name or spare.
At least I now have a very clean workbench and floor :wacko:
Hi, Re our PM's, I have attached a pic of the sizes for KIF springs which I have been using.  The smaller sizes you mention relate to the jewel chaton I think, hence the confusion.  I was unable to send pic by PM so have put it here.  It may also help others.
Kif-Springs.pdf
Thanks to all who helped with this post.  Unfortunately none of the offered solutions were suitable for me.
I eventually ordered a pack of 5 Kif 3-2 (elastor) from Cousins as the Kif6-1 is no longer available and donor movements could not be found or were extremely expensive for just 1 tiny spring.  The Kif3-2 is only very slightly different in design and the overall length is 1.5mm cf 1.6mm (they are unbelievably tiny) but it fits and sits ok.
I did have some fun trying to get it to engage and managed to bend one out of shape, so having 4 spares turned out to fortunate.  I managed to fit using the method suggested by another forum member (cant find who! but thanks for the input), which was to fit the jewel and lay the spring in position on top and then push it into hinge part of the jewel holder. Easier said than done, I failed with tweezers and eventually managed with a 0.5mm screwdriver after about 1.5 hours of trying!!!
The balance seems to be swinging fine so I now need to re-clean and check all is well before final assembly.
Now having a few days winding down rest from this project and doing something a bit easier !!!
Edited by canthus
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
    • I would like to see the movement. The watch is the movement. Anyone can print a name on a dial and sell it as "the maker".
    • Thanks for your answers! There seems to be a contradiction between these two answers, so perhaps I need to clarify. The flat and convex jewels look identical on the side facing away from the pivot shoulder. That is, there is an oil reservoir. I don't know if that changes anything but I thought it was safest to clarify since I didn't include a picture of the jewels from the opposite side.
    • unfortunately paying attention to details bumps up the cost. Which is why they shortchange on manufacturing steps if they can.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  When it comes to tools buy the best you can afford a good set of watch makers screwdrivers if you look after them will last you a life time. I recommend Dumont tweezers Number 3 and number 5 for fine work, you can build up from there. You will need different strength eye glasses. Some now like to work using a microscope. Pliers the box jointed ones are best they don't go out of line.
