Pallet cock
gary17
Hi
I have just started my first rebuild.
I'm hoping to get help.
I'm doing my first rebuild and i've come to the escape wheel and the pallet (the anchor thing with 2 jewels that interacts with escape wheel)
Do they just have to be placed on the jewel? I can see no hole within the jewel to accept the escape wheel or pallet.
It just seems very loose.
Is this correct or have i made another mistake
Thought i would ask before screwing down the pallet cock.
cheers
gary
14 minutes ago, gary17 said:
Hi
cheers
gary
Huh... Very odd that a pivot jewel would have no hole for the pivot. Can you provide a picture of the situation? Could it be a capped jewel but with hole jewel missing?
Edited by CaptCalvin
I think i've explained wrong,There's a hole with a jewel at the bottom of each hole.The pallet  and escape wheel both fit in the hole. but there no hole, In the jewel itself? So the escape wheel and pallet are loose fitting into there holes.
God i hope i've explained that better
apologies
gary
Edited by gary17
Have you looked at any YT vids of how a watch works? Sorry I don't have a link handy but there are a bunch, some of tge old ones from Hamilton and Elgin/ Waltham are superb, very clearly showing the function of each part with animation and everything.
If you can't see the hole you are not using a loupe.
Then if you see the hole, but the wheel or pallet fork fits loosely as in never finding its place , then the pivot has been snapped.
Edited by jdm
IMG_20190812_212534.thumb.jpg.7c7a038331d175ebfb4cca14ebdc7292.jpgHang on
See the two purple hole? the jewel holes? The escape wheel axle or arbour goes in to 1 hole. and pallet? or fork? axle arbour goes in other.?
The teeth intermesh escape moves fork or pallet which then in turn moves balance..
But both escape and fork are loose.
pics
13 hours ago, nickelsilver said:
Yes. But the pallets would line up with the view holes in green and I can't see anywhere else the escape wheel would go.
That's why I think the escape jewel is missing.  It should be in the hole circled by the left green circle.
RMD
4 hours ago, rduckwor said:
Then I see no obvious place for the escape wheel in the plate.
The beauty with escapements is the fact there has been so many different solutions throughout time, take for example the escapement in a pin-lever, sometimes you have them setup like a super duper co-axial speed racer.
So in this case one really can't tell what it is or how it is configured until he posts Pictures of the complete movement, before strip  or at least Pictures of the escape Wheel and fork.
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
