Pallet cock
gary17
Hi
I have just started my first rebuild.
I'm hoping to get help.
I'm doing my first rebuild and i've come to the escape wheel and the pallet (the anchor thing with 2 jewels that interacts with escape wheel)
Do they just have to be placed on the jewel? I can see no hole within the jewel to accept the escape wheel or pallet.
It just seems very loose.
Is this correct or have i made another mistake
Thought i would ask before screwing down the pallet cock.
cheers
gary
14 minutes ago, gary17 said:
Hi
cheers
gary
Huh... Very odd that a pivot jewel would have no hole for the pivot. Can you provide a picture of the situation? Could it be a capped jewel but with hole jewel missing?
Edited by CaptCalvin
I think i've explained wrong,There's a hole with a jewel at the bottom of each hole.The pallet  and escape wheel both fit in the hole. but there no hole, In the jewel itself? So the escape wheel and pallet are loose fitting into there holes.
God i hope i've explained that better
apologies
gary
Edited by gary17
Have you looked at any YT vids of how a watch works? Sorry I don't have a link handy but there are a bunch, some of tge old ones from Hamilton and Elgin/ Waltham are superb, very clearly showing the function of each part with animation and everything.
If you can't see the hole you are not using a loupe.
Then if you see the hole, but the wheel or pallet fork fits loosely as in never finding its place , then the pivot has been snapped.
Edited by jdm
IMG_20190812_212534.thumb.jpg.7c7a038331d175ebfb4cca14ebdc7292.jpgHang on
See the two purple hole? the jewel holes? The escape wheel axle or arbour goes in to 1 hole. and pallet? or fork? axle arbour goes in other.?
The teeth intermesh escape moves fork or pallet which then in turn moves balance..
But both escape and fork are loose.
pics
13 hours ago, nickelsilver said:
Yes. But the pallets would line up with the view holes in green and I can't see anywhere else the escape wheel would go.
That's why I think the escape jewel is missing.  It should be in the hole circled by the left green circle.
RMD
4 hours ago, rduckwor said:
Then I see no obvious place for the escape wheel in the plate.
The beauty with escapements is the fact there has been so many different solutions throughout time, take for example the escapement in a pin-lever, sometimes you have them setup like a super duper co-axial speed racer.
So in this case one really can't tell what it is or how it is configured until he posts Pictures of the complete movement, before strip  or at least Pictures of the escape Wheel and fork.
    • That's very interesting information. I haven't tried to see if my bombé jewel holes have olive holes but I think I should be able to tell on the larger jewels at least. See if I get a chance to have a look later today. This little story was very comforting to read for a "bungler" like myself. That success isn't a given even for a pro. Thanks for sharing!
    • I forgot that I said I would do that. Will take some tomorrow and post them up post haste.
    • I've seen some really nice early 20th century pieces where all the jewels, including center wheel, were convex. Definitely to reduce friction. It can be quite hard to tell if a jewel has olive holes, especially on small sizes, but that again reduces friction- as well as accommodates small misalignments better. Why they aren't used more often? I imagine it was found that at a certain point in the train the actual advantage became negligible, and the added cost on high production movements is why it's not seen on those, just higher-end pieces.   I did an experiment on a little 5x7"' AS 1012 a few years back. These things run OK sometimes, but often are absolute dogs. And AS made gajillions of them. I had a NOS novelty watch in for a service, ran OK flat, massive drop in amplitude vertical. Made like 3 staffs for it trying different pivot sizes, no change. Tried high quality (not Seitz) convex/olive jewels, no change- the original were flat, but could have been olive hole. Same for the pallet fork, then escape wheel, no change. Probably had 20 hours in the watch, new staff and new hole jewels through the escape wheel, no difference in running. Just a dog of a movement. But if I were making a watch I would use them, just because.
    • When Nicklesilver mentioned the use of them on non coned pivots on older high end watches closer to the escapement.  That suggested to me  probably fourth wheels and possibly third wheels. The square shoulder rotatating on the much smaller surface area of a dome as opposed to a flat jewel surface. I'm curious as to why they are not used predominantly?
    • That's what I thought, but as I said, it makes sense. See if any of our pros will have something to add.
