Balance assembly
PeterS
It's more difficult with the balance in place.
You could try tapping an hole on a small alloy block and use a suitable screw to keep the cock in place, with the balance up. Then you let the stud in the hole and set its screw.
Don't forget that you have to loosen the screw before adjusting, to check that the hairspring is horizontal or even let it its own natural position for best consistency across positions.
I typically lay the balance cock down upside down on a mat and then take the balance, hairspring side down, and visually align the stud with the hole and slowly lower it. Then I use a very small screwdriver bit Yellow and tap the stud into the hole from the side. I usually have the regulator arms very close to the stud, but I just watched a pro move the regulator to the opposite side (far from the stud) leaving enough slack to simply lift the hairspring into the regulator arms; while the stud is screwed into the balance cock.
Not always an easy job and takes a lot of experience to get good at it.
Yes. My suggestion to hold the cock with a screw was made to make it easier for a beginner, and avoid the risk of inadvertently touching the hairspring.
I  turn the boot by 90 degrees, loosen stud screw, lay the cock on its back ,balance side up, on cardboard.  *** Insert a needle pin through the cock screw hole to secure the cock on cardboard***  . Lower the complete balance to drop balance pivot into the jewel hole, get the HS inside regulator pins and the stud in the holder hole.
Good suggestion. I have even held the balance cock in a soft vice at an angle. Very risky.
Pretty much the same technique I use.
Thank you guys, it’s in!
I didn’t get to see your messages and carried on fighting with it until I got it in. I held it at an angle following Mark’s video about fitting a new jewel (tightening the stud screw is what was causing me a headache). I wasn’t entirely comfortable doing it and next time I’ll most likely secure the balance with a pin through the cock screw hole to stop it moving around.
He makes it look easy! 7:55
True Mark dose make it look easy, has mastered it.
One advantage of pining down the cock, is the cardboard, thence, nearly the whole bench is to move along with the cock for a mishap. Large cardboard preferably taped onto the bench. Best wishes
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
    • Does anyone knows what size case a need for a dial diameter 20.60mm?
    • Sounds like the story with my Rolex. Poor (expensive) job done by an official Rolex dealer with an "in-house" watchmaker, hence I learned watchrepair and did the servicing myself. Same story as I learned with the Omega 861, again poor job by an "in-house" watchmaker by an official Omega dealer. Once your watch goes through that back-door, you have no idea what is going to happening to it 🫣   Quite nice that they sent back the parts which had been replaced !
    • yes that's definitely not right at all. I have a picture one of my friends has a Omega coaxial there was having issues to lose asking me where he should send it. As that's a specialty watch I suggested the service center. When he got it back he sent me a picture so the replace the dial as you can see the hands the mainspring barrel and I think the price was really quite decent considering all the stuff they can replace. So I do know they do change the barrels but the other person I worked at the service center when I would ask questions and unfortunately I can't remember all the answers. I think a lot of the changing a parts is at the discretion of the watchmaker. Plus I don't know enough about the chronographs and whether that would be considered a vintage watch? I take some of the vintage watches may have been sent directly to Switzerland or another service center. Obviously with a watch like the one down below they probably have a infinite supply of parts is its relatively modern vintage stuff becomes more interesting even the watch companies don't have necessarily infinite supply of parts. But no matter what the watch shouldn't disintegrated six months that's definitely an issue.
