Balance assembly
PeterS
It's more difficult with the balance in place.
You could try tapping an hole on a small alloy block and use a suitable screw to keep the cock in place, with the balance up. Then you let the stud in the hole and set its screw.
Don't forget that you have to loosen the screw before adjusting, to check that the hairspring is horizontal or even let it its own natural position for best consistency across positions.
I typically lay the balance cock down upside down on a mat and then take the balance, hairspring side down, and visually align the stud with the hole and slowly lower it. Then I use a very small screwdriver bit Yellow and tap the stud into the hole from the side. I usually have the regulator arms very close to the stud, but I just watched a pro move the regulator to the opposite side (far from the stud) leaving enough slack to simply lift the hairspring into the regulator arms; while the stud is screwed into the balance cock.
Not always an easy job and takes a lot of experience to get good at it.
Yes. My suggestion to hold the cock with a screw was made to make it easier for a beginner, and avoid the risk of inadvertently touching the hairspring.
I  turn the boot by 90 degrees, loosen stud screw, lay the cock on its back ,balance side up, on cardboard.  *** Insert a needle pin through the cock screw hole to secure the cock on cardboard***  . Lower the complete balance to drop balance pivot into the jewel hole, get the HS inside regulator pins and the stud in the holder hole.
Good suggestion. I have even held the balance cock in a soft vice at an angle. Very risky.
Pretty much the same technique I use.
Thank you guys, it’s in!
I didn’t get to see your messages and carried on fighting with it until I got it in. I held it at an angle following Mark’s video about fitting a new jewel (tightening the stud screw is what was causing me a headache). I wasn’t entirely comfortable doing it and next time I’ll most likely secure the balance with a pin through the cock screw hole to stop it moving around.
He makes it look easy! 7:55
True Mark dose make it look easy, has mastered it.
One advantage of pining down the cock, is the cardboard, thence, nearly the whole bench is to move along with the cock for a mishap. Large cardboard preferably taped onto the bench. Best wishes
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
