Balance assembly
PeterS
It's more difficult with the balance in place.
You could try tapping an hole on a small alloy block and use a suitable screw to keep the cock in place, with the balance up. Then you let the stud in the hole and set its screw.
Don't forget that you have to loosen the screw before adjusting, to check that the hairspring is horizontal or even let it its own natural position for best consistency across positions.
I typically lay the balance cock down upside down on a mat and then take the balance, hairspring side down, and visually align the stud with the hole and slowly lower it. Then I use a very small screwdriver bit Yellow and tap the stud into the hole from the side. I usually have the regulator arms very close to the stud, but I just watched a pro move the regulator to the opposite side (far from the stud) leaving enough slack to simply lift the hairspring into the regulator arms; while the stud is screwed into the balance cock.
Not always an easy job and takes a lot of experience to get good at it.
Yes. My suggestion to hold the cock with a screw was made to make it easier for a beginner, and avoid the risk of inadvertently touching the hairspring.
I  turn the boot by 90 degrees, loosen stud screw, lay the cock on its back ,balance side up, on cardboard.  *** Insert a needle pin through the cock screw hole to secure the cock on cardboard***  . Lower the complete balance to drop balance pivot into the jewel hole, get the HS inside regulator pins and the stud in the holder hole.
Good suggestion. I have even held the balance cock in a soft vice at an angle. Very risky.
Pretty much the same technique I use.
Thank you guys, it’s in!
I didn’t get to see your messages and carried on fighting with it until I got it in. I held it at an angle following Mark’s video about fitting a new jewel (tightening the stud screw is what was causing me a headache). I wasn’t entirely comfortable doing it and next time I’ll most likely secure the balance with a pin through the cock screw hole to stop it moving around.
He makes it look easy! 7:55
True Mark dose make it look easy, has mastered it.
One advantage of pining down the cock, is the cardboard, thence, nearly the whole bench is to move along with the cock for a mishap. Large cardboard preferably taped onto the bench. Best wishes
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
    • Hands up all those who voted to leave the EU 😂, oopsie.  UK has just signed the Hague convention, next year that will provide cross border clout to British courts.
    • Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ?  Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
