FHF69N service
Have just finished editing and uploading this service of a swiss fhf69n movement from a rotary dress watch belonging to a friends Dad.
He'd had it stored for a long while not working so I'm delighted to get it going again for him.
I watched all of the video yesterday. Its funny watching other watch repairer’s work.
For heaven’s sake get yourself a good watch movement holder. That thing you have must be a nightmare to use, it is making you work harder, having to hold the movement in place with your fingers. I’m assuming you oiled correctly and edited parts out. As you say not easy filming without getting in the way. I would think the kit for getting the best is expensive and like all things takes practice. :thumbsu:
This is how I used to work on a standard watch movement. Just giving the basic. After removing the dial and hands. Remove hour wheel and cannon pinion.  I worked from the top. Let the power off. Remove the balance complete and turn it over, remove the balance from the cock and place it in lighter fluid and cover, remove ratchet wheel and all parts on the barrel bridge. Remove the main plate; remove all the train, then pallets. Open the barrel and remove arbor and spring. Turn movement over, place on a piece of tissue, and remove all the keyless work. Place all parts into the basket and clean. If the Incabloc is really gummed up then remove, otherwise leave it. A good machine and clearer will do the job.
I noticed you did not spin off the cleaner before putting it into the rinse. Did you edited that?
As I said this is very basic.
Its this one. It won't hold p/movements, but will hold most watch movements securely. It will make your work much more easy. Don't buy cheep holders because you will just have trouble with them as you have now.  This is made by Star. I don't know if you can still get them. I have seen second hand one on ebay for about £10
Star-Vintage-Star-Watchmakers-Bottle-Cap-Watch-Movement-Holder-Watch-Tool-2991a1-2528016931.jpg
On 8/11/2019 at 10:24 AM, oldhippy said:
[I watched all of the video yesterday. Its funny watching other watch repairer’s work.]
I watch a variety on YouTube. Often I have one playing as I strip a movement, I find them quite soothing.
[For heaven’s sake get yourself a good watch movement holder. ]
Normally I'll design and 3D print a holder, if you look at my 7019A reassembly video you'll see an example, I prefer the printed ones over any other as they're strong yet being plastic won't mark or damage the movement. This was the only holder I had to hand that would 'sort of' hold this movement, it was indeed awkward, I've found every bought one I've tried is awkward in some respect hence printing my own but I didn't have to time to measure up. Draw and print. Especially given the shape which is a bit trickier to design in cad software than a round holder.
[I’m assuming you oiled correctly and edited parts out. ]
Yes. The video would have been closer to an hour if I hadn't trimmed it down.
[I noticed you did not spin off the cleaner before putting it into the rinse. Did you edited that?     ]
Yes, (see above).
I did film a bit more of the cleaning machine which I plan to make a separate video on independently showing the whole process, (obviously not the whole 15 minutes of it spinning) but the cleaning. Spinning off, 2 rinse baths then the dryer.
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
