Help Identifing a watch Citizen
I am trying to find information on this watch. on back of cast: Citizen 25 Jewels  4-760182TA BLG-K GN-1-S  and Japan imprinted on bridge. On the front Citizen Automatic.
This one was fixed in the past and the gentleman removed the second hand and the post that it runs on. I am wondering if he changed out the cannon pinion. If someone knows where I can find parts or and old movement I could strip down to replace what is missing that would be a big help.
Client said this came from an uncle that owned a watch repair shop in the 60's. He told him that this watch was a  Dealer example to show the customers how the watch worked. I would really like to find and replace the original second hand if I could.
Thanks, Charlie of OldManTique
Edited by Charlie925
More information to add.
That is a Citizen Skeleton . I had one of those . Dropped the clutch wheel when servicing it . I search almost everywhere for a replacement.  I ended up selling it as donor watch.
Maybe it's easier to find one today? Think the movement is 7290 ?
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
