Seiko Echalon shock spring tool
Colditz
Is  there a tool for installing the echalon shock spring as used by Seiko? I tried with two pairs of tweezers and it is so difficult. Mark makes it look easy. When I tried it it pings everywhere. I even tried putting a thin plastic bag over it while trying to engage the ends. Failed miserably. I've had to hold this one in abeyance till I get the nerve or the tool to try again.
You mean Diashock, and I assume of the two legs type.
Either use a single set of tweezers, slightly fit one side first then the other. Otherwise file and hollow a pegwood stick to match the size and proceed as in my video below.
However I recommend that one learns to do that with tweezers, to develop dexterity for this and other tasks.
Edited by jdm
1 hour ago, Colditz said:
I stand corrected it is a diashock / diafix.
That is a Diashock, the Diafix is earlier and different,  you can use either methods from my posting above for 100% sure results.
Edited by jdm
     "get back on the horse" - vin
 If you are using my bag trick( tips on removal/ replace fidly jewels) , stick the sharp point into the palstic bag.
If you are concerned about pushing on pivots, I often remove the balance wheel, get the sledge, with balance removed you don,t have to be so cautious.
Perhaps your first encounter, but this one is real easy, you,ll master it quick.
They can take a bit of getting used to, that's for sure! I certainly had a few ping around the room. There's a great guy called Adrian who runs VTA in Australia, they specialise in vintage Seiko and suchlike. Adrian was kind enough to make a great tutorial video; helped me a lot and following this method I've had no real dramas since.
Hope this helps.
Phil
*Edit - link to the video I was actually talking about!
*Edit:The original video I posted below is actually from Mike at My Retro Watches. Another great guy but he's based in the rather less sunny climes of Coventry in England!
Edited by Pip
