Omega Watch - New movement
11 hours ago, jdrichard said:
I have an omega Speedmaster Automatic Chronograph and I would like to put in a new, reasonably priced, replacement movement. The movement can even be (brace yourselves) Quartz.
 a4dcbc7bd0179b648b238c83a8b3fe9e.jpgfc5e61484f641226f80966f1639b3d89.jpgb65b218e0c8de2e46df3afd1c2911964.jpg
The watch isn't authentic, but you probably knew that.  You might be able to find a replacement Chinese chrono movement.
1588666478_ScreenShot2019-08-05at9_05_58PM.thumb.png.97602964f47be523dcdc520cbfae3292.png
I guess your posting is made tongue in cheek like mine ;-)
In reality The Chinese don't make chrographs. At most month, lunar and some more indicators e.g. in the one you have linked.
Doesn't Tianjin make chronos? I believe they're called Seagulls, but this isn't one of those. You are correct JDM, the subdials on the movement I suggested usually indicate day of the week, month or some other thing like lunar cycle. IN  the case of this faux Speedy, it is possible they simply spin around with no real elapsed time function--looks that way from the photo too!
Joe
 a4dcbc7bd0179b648b238c83a8b3fe9e.jpg&key=2bbc5c58a5fa5ef9372f403366b4201d718f6b0733ac15adb89ad9d4f49d5003fc5e61484f641226f80966f1639b3d89.jpg&key=ba61e82306f129eac8c7395750f128436903ee9ae17a6d2bee572289ed2c5a9cb65b218e0c8de2e46df3afd1c2911964.jpg&key=59460d281caea7387e17bd23a7827fa6f54c53f4224a3896dceeba2220134195
Seeing the back of the movement I suppose it's a faux-chrono and the subdials are not working.
Possibly a modified Hangzhou 2813.
You could have a look at cousinsuk website and search the Chinese movements list for a movement with the same specs.
Envoyé de mon moto g(7) power en utilisant Tapatalk
    • Hi, guys I have a bit of a predicament and hopefully, somebody can advise. I'm working on a Roamer MST 521 where the movement is extracted from the crystal side. I'm now at the final hurdle where I need to replace the movement back into its case but I'm not sure of the correct procedure. I still need to fit the hands but that's where the problem lies. If I insert the winding stem to test the hands for correct alignment I will need to turn the movement over to release the stem again it's the spring-loaded type and needs a small bit of force to push down but with the hands fitted, I don't think I can do this on a cushion without causing some damage to the hands and that's the last thing I want to do, this watch has already been a love-hate relationship and I'm so close to boxing this one off which I'm counting as my first major project.  The other option is to case the movement then fit the hands and hope everything is okay. I've already broken the original winding stem but managed to find a replacement, the last one in stock, so I'm a bit reluctant to keep removing it. Any suggestions would be appreciated.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
