Hi there!
SiZi
I have just completed two courses on watch repair by Mark, and I am in the process of servicing my first watch - a 565 cal. Omega Seamaster from 1979.
I have owned an automatic Tag Grand Carrera cal. 8 for the past decade, I don’t have any other watches apart from that.
While I am new to restoring watches, I do have a few years of experience restoring vintage fountain pens. I have a modest collection of pre 1950 MBs, and I also have a website dedicated to vintage montblancs.
Anyway, I hope to learn much from this community and contribute to the pool of knowledge being built here!
On 8/6/2019 at 12:11 AM, DFeryance said:
It may be wise to start on a watch movement you don't care about. It is easy to loose parts or break something. I also just finished the first two of Mark's courses and I am working on some cheap movements I got off of ebay. Just a thought.
Yes that would be wisest. I got this off eBay for a decent price - cheap enough to not hurt too bad if I mess it up, but at the same time nice enough to care about actually succeeding. You know what I mean?
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is. I've attached a lesson regarding mainsprings, focussing on the size and strength of the spring within the barrel, you might find helpful. Unfortunately it is a PDF converted from a PowerPoint presentation, but only a slide was lost that was originally a video of fitting a mainspring   Lesson 5 The mainspring.pdf
