removing a rotor of vintage citizen watch
Hello watchmakers!
I am about to work on a vintage citizen watch.
I removed the movement from the case but I am stuck on removing the automatic rotor..
It seems that my screwdrivers won't do the job..
Any advice would be helpful thank you.
The tool needed to remove the nut is described in that second PDF, around page 32 in my PDF reader.
You should be able to make something similar relatively easily from a piece of round stock, perhaps an old screwdriver blade with sufficient meat on it, by cutting a suitable slot in the flattened end.
Note the direction that it tells you to turn the tool. That sounds like a standard thread rather than a reverse one. Normally it is lefty, loosey, righty, tighty. i.e. Anticlockwise to undo and clockwise to tighten.
I would take the time to make the tool, as otherwise you risk marring the end of the "nut" on the weight.
Edited by AndyHull
I use an old bronze tweezer . Hold it over and use the left hand to press around when unscrewing . have worked for me so far. But as i saw the picture of the tool. I wonder if i don't have a screwdriver here that is for that . Always wonder what it was for. I will go and have a look.
Edited by rogart63
Found the tool . But couldn't find the movement right now . Is the nut approx 2,1 mm .  The citizen i had in was a 52 -.... diver . Which i thought should have a movement with such nut. But it had a normal 8200  movement. Great for me as i found those movement a pain to service. 5270 and 7270 isn't that the numbers. Have 200 clicksprings on the date mechanism :)
14 hours ago, jguitron said:
I found one on eBay that worked perfectly fine at a very reasonable price.
Nothing else I tried worked!
Good luck.
17 hours ago, watchweasol said:
Thank you everyone for your generous advice.
I will try the tweezers!!
Hey guys! Just wanted to thank you because of you guys sharing all this information I got to put back a similar citizen for my dad!
I did not find any info on the movement (maybe did not use the right words) so took the thing apart blindly.... But just before putting back together I found this thread and got the manual someone shared! Thanks a lot.
  • 3 months later...
  • Similar Content
    • I have it, so until we get a lunch one day , nearly everyday is with my mum at the moment.
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
