Repair Rub In Jewel Setting
So, I was somewhat cavalier trying to replace a rub in jewel. I don’t have the correct tools but thought I could expand and close the hole with nothing but my jeweling tool, some peg wood and my wits. It didn’t go well. I’ve taken a big. chunk out of the thin metal that wraps around the jewel. To be fair, the jewel still sits in the hole and feels relatively secure with only 200 degrees of metal holding it in place. But I just can’t close the watch knowing it’s been bodged. So is there a technique for replacing a rub in jewel setting if it’s damaged? I’m guessing it needs drilling out and soldering in a new setting. Which would be beyond me for now. Is there another way?
Thanks both. Could this help me create a new larger hole? And I'll just find a suitable jewel to fit? I've never seen one of these before and I have no idea how they work.
https://www.ebay.co.uk/itm/Vintage-Watchmakers-Jewellers-Brass-Jewel-Hole-Cutting-Tool-Set-Boxed/383062301696?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
That's for making a new setting. I haven't used one either but it's a neat looking tool.
A big problem when replacing bezel set (rubbed in) jewels is that the brass or german silver is often quite brittle. If it's a regular commercial grade watch and you don't mind altering it, the easy route is to ream the setting to the closest friction fit jewel that will go. In some cases you can use the "walls"of the old bezel set jewel. If it's a nice piece, like an old LeCoultre or something, I will open up the bridge or plate in a faceplate. There is almost always a polished sink around the setting; I'll open up till that is gone. Then make a new setting that frictions in, which gets the polished sink on the visible side, and the repair is effectively invisible.
Well I purchased that tool. Just because it looks really interesting. I'm not sure how it works but I have plenty of scrap movements to practice with.
I might see if it helps me make a new setting. But more likely I'm going to ream out a friction fit hole as suggested by Nickelsilver above.
The question is, what stone should I buy?
The jewel is for a pallet fork (lower). The fork pivot is 0.141 according to my super accurate micrometer. If it's anything to go by the upper jewel hole looks to be around 0.2mm. But it's tricky to measure. Would a 0.2mm hole be correct for a pivot of this size? I'm not sure what the ratio of pivot diameter to hole diameter should be for a pallet fork.
I measure the jewel setting diameter 1.51mm. But it's also difficult to measure.
I was thinking of going for a Seitz flat jewel 1.6mm with a 0.2mm hole. (Seitz don't make an olive jewel in this size.) Does this sound sensible?
So, here is the interesting jewel cutting tool from eBay. Just arrived today. It's really nifty. I can't find anything about how to use it so I'm making this up as I go along.
Let's define some technical terms.
1) Turny bit
2) Spiky thing
3) Edge gougers
4) Locking screw
5) Size guide
6) Maybe thing for a bow
It appears that you place the spiky thing into your desired jewel hole on the size guide. You turn the turny thing until the edge gougers fit into the guide edge of the hole. Then you lock the spike with the locking screw.
The edge gougers are clever. Each one is split. So I think the inner gouger carves out the floor of the setting for the jewel to sit on. And the outer one creates a wall that you can later use to bend over the jewel and secure it. Because am I right in thinking this is producing a rub in setting?
I had a couple of gentle attempts on a thin scrap piece. I used it to ream an existing hole. I would presume you need a pilot hole to start with close to the correct size. I wouldn't like to use this to make a hole from scratch.
I am using this freehand. But would you agree that 6 could be a thing to use a bow? Like you would with a jacot tool? But then the tool needs to be held on some kind of stand or device to keep it vertical and steady. So I'm not sure. It certainly doesn't feel very ergonomic using it freehand.
And why are both ends spiked?
The rear point would have fit in a divot in a vice to support it while it was worked with a bow. The plate would be handheld. Yes you need a premade hole to begin with.
Watchmaker's vices used to come with the little divots in the jaws for the many bow powered special tools.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
