what do i do with my mainspring?
Hi All
I really hope some knowledgeable bod/s can help.
I'm renovating a felsa 690 movement, it has a broken mainspring but there is also a brake spring in the barrel too. What greases should I use and where for best running?
Thanks in advance
Sorry, I don't think I explained myself clearly... I have the chart, but not sure if the barrel wall is greased along with the inside of the brake spring.... I've not come across a brake spring before...
2 minutes ago, watchweasol said:
Hi    Leosics.co.uk  have a comprehensive chart  giving all the oils and greases and uses therof.
8 hours ago, vinn3 said:
  "brake spring"?   is that part of the main spring.
it is a separate spring part that fits between the mainspring and barrel wall, I'm unsure if i should grease everything or not or if i should use different greases for different contact points of the spring. i can see 2 points of contact i.e. where the brake spring contacts the barrel wall, and where the mainspring contacts the brake spring...
The attached doc doesn't state it and the mobius chart doesn't cover it...
2763_Felsa 690.pdf
Probably the brake spring isn't supposed to move so just  were it contacts the mainspring. The latter is not greased at all. Only a minimum amount on the barrel and lid flat faces perhaps, even that is optional.
2 hours ago, oldhippy said:
jdm is correct. That part should not move. so there is no need to do anything. Just oil the m/s with the correct oil.
Thanks for clarifying, chaps!
Do I still need to lubricate the inside of the brake spring for the main spring? or is it an oil-less system?
This is an automatic watch. You can replace the broken mainspring with an automatic spring, with integral slipping bridle (brake spring). Or you can use a standard spring with your separate brake spring.
Either way you need to grease the barrel wall with braking grease.
   i would go with a standard spring if that will work.    ive had bad luck with watches with a "clutch"..   i believe it was pattented by  movado years ago.  vin
Thanks guys.. but I am one fraction more confused now after reading the service guide regarding the mainspring
"Grease the entire inner circumference of the barrel. Fit brake spring, bending it as little as possible, then fit mainspring, oiling it in the ordinary
way. The winding may be checked by locating the barrel in the movement,"
These instructions seem to be at odds with what I have seen re greasing the barrel of a typical automatic mainspring. Ive never encountered a brake spring before and it is really confusing me with what I should do for best results...
12 minutes ago, nickelsilver said:
Back in the day it wasn't uncommon to have a separate slipping bridle that functioned with a normal spring. Either way you need to grease the wall. If using a regular auto spring you won't reuse the separate bridle.
Ive bought a direct replacement from Germany, NOS I Believe. I don't Mind reusing the Brake spring, just not sure what to grease. Also.... Daft question but I forgot to record the direction of the overlap of the brake spring... is the mainspring supposed to catch on the overlap or slide past it?
Sorry for the silly question...
22 hours ago, nickelsilver said:
Can you post a pic or two of the brake spring?
Thanks for your input nicklesilver.
sorry for the quality of the photos. 1st is the brake spring, there is a small peg at one end, just viewable in the pic... the second is the old mainspring in situ.
If I look closely at the barrel pic it seems that the mainspring bridle sits on the 'peg' and it would be the brake spring that 'slips'. is this correct?
What oils should I use to lubricate which surfaces? I have D5, 8200 , some 9217 (on the way) and although not relevant some 9010.
Thanks again for your input.
On 7/30/2019 at 8:32 PM, nickelsilver said:
Ok, the little bump is to catch the bridle on the mainspring. It probably has a "hooky" side and a less or non "hooky" side. It's been a while since I used one of these but seems there's really only one way it can go.
Thankyou nickle silver, much appreciated.
    • I have it, so until we get a lunch one day , nearly everyday is with my mum at the moment.
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
