Bent Banking Pin
Currently working on a Gruen Guild, Semithin, 16 jewel, 12s that is in nice shape for it's age. Seemed like it was just dirty and dry but I've found what might be a problem with the banking pins. One of the pins is bent over quite a bit and has a gouge on the pallet fork side of the pin that pretty clearly shows it was bent over on purpose. The other pin looks a little bent too but not as much.  I don't know if I should clean and lubricate the movement and see how (or if) it runs or try to straighten the bent pin while reassembling. The roller jewel seems to line up between the pins but the fork swings much further on the side with the bent pin.
One thing I've never done, as I've pursued learning watch repair at my hobby level, is try to adjust banking pins on any other work I've done, and I have very little knowledge of checking the run to banking. The pins appear to be pressed in to the plate and not adjustable. Any help is greatly appreciated.
I would see how it goes first. From the look of the pallet bridge and the screw it has had some very bad treatment. Banking pins are not the sort of thing to play around with, all sorts of problems can happen in and around the escapement.
flow-chart-did-you-mess-it-problem-solvi
That has the look of "apprentice marks".
I wonder if the palette bridge gouges and the bent pins are part of a nasty apprentice + screwdriver related incident.
Maybe the screwdriver was applied with a little too much youthful exuberance to the screw and afterwards said apprentice checked it still ticked, hastily buttoned it back up and gave it back to the customer. "Nothing to see here sir. Working fine now.  That will be fifty bucks. Thank you sir and have a nice day."  per the instructions above.
Edited by AndyHull
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
