Bent Banking Pin
Currently working on a Gruen Guild, Semithin, 16 jewel, 12s that is in nice shape for it's age. Seemed like it was just dirty and dry but I've found what might be a problem with the banking pins. One of the pins is bent over quite a bit and has a gouge on the pallet fork side of the pin that pretty clearly shows it was bent over on purpose. The other pin looks a little bent too but not as much.  I don't know if I should clean and lubricate the movement and see how (or if) it runs or try to straighten the bent pin while reassembling. The roller jewel seems to line up between the pins but the fork swings much further on the side with the bent pin.
One thing I've never done, as I've pursued learning watch repair at my hobby level, is try to adjust banking pins on any other work I've done, and I have very little knowledge of checking the run to banking. The pins appear to be pressed in to the plate and not adjustable. Any help is greatly appreciated.
I would see how it goes first. From the look of the pallet bridge and the screw it has had some very bad treatment. Banking pins are not the sort of thing to play around with, all sorts of problems can happen in and around the escapement.
flow-chart-did-you-mess-it-problem-solvi
That has the look of "apprentice marks".
I wonder if the palette bridge gouges and the bent pins are part of a nasty apprentice + screwdriver related incident.
Maybe the screwdriver was applied with a little too much youthful exuberance to the screw and afterwards said apprentice checked it still ticked, hastily buttoned it back up and gave it back to the customer. "Nothing to see here sir. Working fine now.  That will be fifty bucks. Thank you sir and have a nice day."  per the instructions above.
Edited by AndyHull
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
    • Sirius. Thank you for helping others with that information. This is why this forum is so good.
    • Yes watchie , the indirect center seconds wheel. Also known as a sweep wheel remover.  If you zoom in to pullers you will see one plain bent puller and the other is split to bridge over one of the spokes. Cousins have been out of them for ages , they say the manufacturer for them for bergeon is no longer in business. Another company is supposed to be stepping in whenever that might be. The new ones dont look as well made as the vintage ones, but thats standard these days. I know you prefer the old swiss tools anyway.
