Thank you Rogart63
Today this package from sweeden came in mail, containing 11blacd escapement wheel, donor  @rogart63 .
Following fourteen years of in to do box  I will hopefuly  bring my bulova snorkel back to life and  soon, I will post a picture of it on watch of today thread.
Thank you Rogart63 for this gift, very precious to me. In appreciation of your generosity and in your name, I make sure to pass on three winding stems to the novices and three balance staffs to experienced learners.
I have no problem shipping small parts.
  • Like 6
44 minutes ago, oldhippy said:
What a nice gesture  rogart63:woohoo-jumping-smiley-emoticon:Its things like this on this wonderful forum that make the place  it is. :thumbsu:
If i have the parts i am willing to share. I can't use them in a lifetime. And lots of the movements are in bad shape .But some parts look fine. Could be hard to sell if i can't guarantee they are 100% perfect either. So as we all tinker with watches in here and can inspect the parts i send.  It's nice to help out . Some other time it's maybe me that is searching for some hard to find part.
  • Thanks 2
30 minutes ago, MrRoundel said:
I concur, rogart63 is a jolly good fellow. He sent me parts for a movement a couple of years back. Saved my bacon. :Bravo:
I was in this predicament with no available instrument for small payments. No online source domesticaly.  Real nice of Roger to help. I say that pass on program can be real life saver if in the true spirit.
Just to add my poundsworth and appreciation:-
Rogart63 also sent me some watch parts a couple of years back and, like others' on here that have found out,
Rogart63's kindness, thoughtfulness and generosity, resurrected (In my case) an old watch from oblivion.
He is, without doubt, a Gentleman.
(Yes, I did "thank him." )
    • As an experiment i was thinking of not hardening it to see how it fairs. Now that i have a complete template i could knock up another in half the time if this loses its elasticity. I might play about with a few pieces today to test their bending and spring properties. This was cs 100 the supplier quoted in annealed state, it was nice to work with files so I'm taking it thats its state. What you are looking seems like it would need annealing to work it. This is why i went for this stuff that cuts out that process, it was so easy to work.
    • Showing state of hairspring on receipt, backplate & 'dished' wheel.  Thanks, Nev. Amplitude v. weak - balance wheel turns over arc of only ~20deg. Don't know how to calculate movement rate or safely vibrate balance spring! Meantime I have reduced the 'dishing' & clock no longer runs for more than a few minutes except face down which supports my theory that it was 'dished' as a hack to avoid doing a proper repair.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?       Have you seen this video, he shows how to determine where the indents go ?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
