107 Timex Automatic - Before and After
JerseyMo
Ahh.. 1978 - the first episode of The Hitchhikers Guide to the Galaxy was transmitted on BBC Radio 4 (and received by your truly on a battered old transistor set he repaired himself), NASA launched the  Pioneer Venus Orbiter, the Afghan civil war began (and is still going), Jimmy Carter is US president and James Callaghan is PM here in the UK, and somewhere in the world, that Timex came off the production line.
I have one of those I bought from you @JerseyMo off of ebay about a year ago. I love that model. The dial has slightly different writing so I presume it is a different year (maybe the 31 movement?) but overall looks the same. I put it on an olive nato inspired by the Todd Synder watch and have gotten comments on how nice it looks. My wife generally hates natos but admits it looks nice on one. I also looked into the Todd Synder quartz but much prefer the original mechanical.
I am surprised at how well the chrome has held up, both on my watch and the one you picture here. Some scratches, but no clear brassing areas.
20 minutes ago, AndyHull said:
1978 produced some real design classics from Timex.
This is one of my favorites, and my "Watch of Today".
It may have a few minor battle scars, but it certainly lives up to the "Takes a licking, keeps on ticking" (loudly) boast.
have you noticed that the case is the same?  By this time the case were interchangable, with manual or autowind.  Only difference would be to use a different case back.  YOu could alos turn a 107 into a 109 and stuf like that.  The only difference is the top bridge which is removable and can be swapped out.  But damn the designer who came up with the f**# forked tounge click.
I have an old Timex Model 87 (84 Series) Back Set Electronic watch (965608772) - circa 1972. It was my dad's and has been sitting since the mid-80s. I put a fresh battery in it and can hear the movement working. However, it doesn't tell time. I did the rotary shake to give it a kick-start and it ran for 10 minutes and stopped. The movement is apparently removed only by removing the crystal ... which I have no tools to do. When I turn the hands to set the time, the second hand spins extremely fast around the dial several times. It is very sentimental to me and I would like to get it working again. Even to swap out the movement or convert it to quartz. Any suggestions would be most appreciated. I live in New Jersey. Thanks again!
  • 2 years later...
On 7/22/2019 at 9:55 PM, JerseyMo said:
Before - and - After  107 Timex Automatic.  This model orginated with a 31 automatic and was later made with the update 107.
This watch insored designer Todd Synder to create a monern version.  Actually quite a nice homage but saddly only a quartz :)
https://www.toddsnyder.com/pages/the-military-watch-by-todd-snyder-timex
Hello Sir!
Do you recall what size crystal you used on this one?  I won an auction and I think I'll have to replace the crystal on my forthcoming project.  Looking forward to restoring the one I'll get later this week (fingers crossed).
Thank you!
  • 4 months later...
I just picked up this 1977 Military Style watch and plan to start restoring soon.  It runs when laying down but has issues at other positions.  I believe a good cleaning is in order for starters, but would like any suggestions on how to move forward.  I have several Marlin's and another Viscount as well as about 8-10 Timex movements, which I have brought back to life cleaning with lighter fluid and using some Mobius 9010 in the pivot points.  I'm mostly curious how the movement is removed and I'm guessing the crystal has to come out.  By the way JerseyMo your finished watch is absolutely beautiful!
the movment comes out the back.  remove the rotor first, than stem than clip.
    • Haha. You're just in a wicked mood today John 😅
    • Heres my watch of today, a Smith 13'" RY . My missus bought me this for this Valentines day a bargain 14.99 with a reduction, the seller has occasional 20% off offers now and then so it was about 15ish with delivery. I love Smiths and i love bulleye dials, this is my first one. The watch arrived non working as stated and i knew what was inside and what would be against me, but i enjoy a challenge, we dont expect a lot if anything from pin pallet movements. A balance pivot was broken and i didnt have another staff but i did have another RY with a battered dial so i robbed the balance and tweaked it around to make it work apart from that mostly just a good clean and relubrication. Keyless works are pretty rough by design and the crown is a bugger to get in and out with the dial on, the setting lever hits the dial before it releases it, so a little mod is needed to help that along. Major problem was the pins on the lever were quite worn which make the old tg have a snow storm fit. Its a similar read for most pin pallets, these were brass as was the escape wheel. But perseverance is me, i didn't change the pins but i did spend some time dressing and polishing the worn areas which improved the trace a lot with some straightish lines 😅 and a beat error of .5 . Not sure what the lift angle should be on these and i Wasn't in the mood to work it out and who believes timegraphers anyway, but at the default 52° it runs with 260ish full 210 after 24 hours dial down , the verticals rates were pretty much all over place. So lets just put it in it's superlight aluminium case and see what happens. Been wearing it now for 3 weeks and it's consistently losing around 1.5  minutes a week winding each morning i think pretty good for an old pin pallet watch. I just love this dial, thanks wifey heres my Valentine's gift for yer sweetie x
    • I have a PDF below that will help. The problem was the PDF wasn't designed for this purpose it was designed to tell you what size watch you  have. Then it doesn't take into account movements come conceivably in different thicknesses.   watch-ligne-size-chart.pdf
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
