Elgin Puzzler
I have a very nice Elgin 714 movement that has me stumped. Cleaned and lubricated. The train runs and spins very well. New mainspring, settings on the balance cleaned and lubricated, Hairspring looks fine to me.
I cannot get it to run for more than a few seconds after puffing the balance wheel. I pulled the settings and end stones today and cleaned and lubricated them again, they are in place correctly, but no difference. The pallet and it's pivots look fine and so does the balance and hairspring. It just doesn't seem to get any kick back to the impulse jewel. (It looks to be fine as well.)
Please give me some troubleshooting ideas.
Thanks,
RMD
Hi The train wheels are all free running,  does the pallet (fork) snap backwards and forwards cleanly when moved, without the balance in , If the action is sharp and crisp the fault lies within the balance area, Is it in beat is balance spring fouling the cock, is the spring concentric, is impulse pin loose , Pallet stones in good shape and not loose, pallet stones locking and un locking ok these are but a few pointers to check before trearing it to pieces again. Doubtless other members will have other actions for you to look at.
  • Haha 2
Thank for the reply.  Yes, all of the above have been evaluated.  That's why I am puzzled with the failure to run.  I will remove the balance today again and break it down for more thorough evaluation. I may well start substituting parts from scrappers as well.
Thanks,
RMD
1 hour ago, watchweasol said:
Hi Indeed a puzzler, Have you tried removing the pallet and just fitting the balance on its own and using a small artists brush checking its action,  just a thought.
Yes, Been there and tried that.  Not as free as I would like but free enough I suspect.
Thanks,
RMD
Thanks,
RMD
I'd be looking to see that the pallet has good "kick" when gently pushed to one side and the other with the balance removed. I'd also check the clearance between the hairspring and bottom of the balance cock. I would also try reversing the balance jewels between the cock and pillar plate. It's amazing how many times those get switched. Not by us, but perhaps any time over the many decades of service. Good luck.
Well, I just substituted a balance from a 711 I had lying around and it kicked off immediately.  I know I didn't switch the balance settings, but the advice that someone ahead of me might have is very timely.
Thanks,
RMD
    • yes that's definitely not right at all. I have a picture one of my friends has a Omega coaxial there was having issues to lose asking me where he should send it. As that's a specialty watch I suggested the service center. When he got it back he sent me a picture so the replace the dial as you can see the hands the mainspring barrel and I think the price was really quite decent considering all the stuff they can replace. So I do know they do change the barrels but the other person I worked at the service center when I would ask questions and unfortunately I can't remember all the answers. I think a lot of the changing a parts is at the discretion of the watchmaker. Plus I don't know enough about the chronographs and whether that would be considered a vintage watch? I take some of the vintage watches may have been sent directly to Switzerland or another service center. Obviously with a watch like the one down below they probably have a infinite supply of parts is its relatively modern vintage stuff becomes more interesting even the watch companies don't have necessarily infinite supply of parts. But no matter what the watch shouldn't disintegrated six months that's definitely an issue.
    • glad it worked out, those ESA movements are obsolete but new old stock is still out there, now that you know the make/model you could also do a cross reference to see if something more current would line up with the dial feet and hands...for future use if needed 👍
    • I wish they would have done so in this case. The whole story went like this: I sent my speedmaster to an omega service center about 10 years ago (at that point of time I haven't even started watchmaking). After the watch came back to me it had only about 6 months wristtime until january 2024 (not fair for this nice watch but the other pieces of my collection want wristtime too 🙂). So my conclusion is that the barrel was already faulty when it came back from service, can't imagine that amount of wear in 6 months wristtime. In january 2024 the performance on the wrist was quite bad, so I decided to have a look by myself. I have to admit that I didn't check the barrel close enough as I thought it must be ok, couldn't have issues after official omega service. That was a mistake, I will learn from that. Follow the golden rule: Nothing is certain except death and taxes.
    • I am same as you oldhippy I won’t touch anything with a battery, I keep getting requests to but I just say I only do mechanical clocks, there are quite a few errors & omissions with the repair guide have a look at this. https://mb.nawcc.org/wiki/Encyclopedia-Subjects/Torsion-Clocks/Book:Horolovar-400-Day-Clock-Repair-Guide-10th-Edition-Errors-and-Updates
    • Nice experiment. As it will be no problem, please put a twice less mass (half of the two penies) and read the amplitude, will be interesting. I mean to determine what is the relation torque/amplitude.
