  • 0
bcpitch5
Hamilton 974 Hands Not Moving
Question
I have this Hamilton 974 pocket watch. It is running strong however the minute hand move stops at 12:05 everytime it is set at 12 o'clock (the watch keeps running after the hand stops). I've replaced the cannon pinion, and the center wheel (center wheel was a tiny bit bent which I thought was the problem). I've watched it running and all of the train wheels are moving but the hands are still stopped. Any ideas?
Share this post
Link to post
5 answers to this question
  • 0
24 minutes ago, Nucejoe said:
Have you tested the hand tubes for binding, just remove the hands, see if stops at 12.05 .
Canon pinion rubbing on mainplate?
The watch never stops, just the minute and hour hands at 12:05 (seconds hand still tics). I've replaced the hour wheel as well and the cannon pinion isn't rubbing. I can't understand why they would move for 5 minutes and then stop every time even though it still runs. If something was binding I would think it would stop the whole watch?
Share this post
Link to post
  • 0
I think this is possible if there is very low friction to the cannon pinion. The balance and the trainwheels run but the cannon pinion and all following wheels and the hands do not as one of these parts is stuck somehow.
I would try and analyze step by step. Take of dial, hands, hour wheel and intermediate wheel, put the minute hand on the cannon pinion and observe.
If the minute hand does not stop at 12.05 take the next step and add the intermediate wheel and observe. After that add the hour wheel and so on until you find the step where the error occurs.
Share this post
Link to post
  • 0
I figured it out. I totally overlooked that this particular 974 has the little blue locking screw to lock it in the winding position when out of the case which explains why the hands wouldn't move. I didn't have it locked which kept it in the setting position when out of the case and thus not having enough power to turn the hands....I'm an idiot :biggrin:
Share this post
Link to post
  • 0
A lot of Walthams have a mechanism like that. It is a little sliding lever that actuates what they call the shipper. The lever sets into a narrow groove on the top side of the pillar-plate. I was unaware of the Hamilton using such a feature. Nice that you figured it out. Cheers.
Share this post
Link to post
Answer this question...
Loading...
    • Some updates, I measured the  mainspring barrel of a 6498 and it's 16mm. I also tried loading a 10mm mainspring on an undersized winder, it did not load fully. So I answered my own question hehe. thanks.
    • Thanks. A small correction to my earlier post,  it is a Poljot 2614.2H, not a Vostok. http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Poljot_2614_2H
    • I've been thinking about getting a Russian watch myself. Nice piece Andy.
    • This is the progress so far. The first image is the ebay seller's pic and the description was "Does not start, maybe battery but unable to confirm". In reality, it wouldn't wind, wouldn't set and the scratched up crystal looked even worse in real life (and the second hand had fallen off in the post), but I figured it had to be the twin of the one I already had, and therefore was well worth the 0.99p I bid.
    • Thanks for the correction regarding the movement. You are spot on  with the fiddly calendar works, the first one I looked at, I launched those two springs more times than I care to mention, however forewarned is forearmed, so this one came as no surprise, and I even remembered which way round everything went without having to dig out my pictures of the first teardown.  If you are aware of the issues and take care to do things very gently, the calendar works go back together reasonably easily. I did mange to gocha myself with the keyless works by pulling the crown out with the stem in the wrong position, but I knew I had been an idiot the moment I did it, so I only managed to indulge in that one screwup. The watch is running well, but I haven't attempted to adjust it yet. Beat error is around .1 to .3ms and it kept up a good pace, within 20 seconds or so over the course of the day even without me tinkering with it. I'll let the lubrication settle and do a bit more with it tomorrow. The amplitude is still a little low at around 240 fully wound, so there is scope for a little improvement in that too. The other one runs around 270, so there is no reason to think this wont. I have an almost complete spare movement, including a mainspring, etc.so if I need parts I have them.   That red and gold Poljot on your "About me" page is a cracker, as are the others in your collection.
