Landeron 248 modified 4th wheel
Hi Gents,
Currently, I try to recondition a 1970 Regency chronograph with a Landeron 248 movement.
Everything is going fine so far. Ordered new mainspring, glass, gasket and pushers as they were a bit stiff. The case itself has been replated as it was also quite worn. I dismantled the whole movement and this is where I have some problem and I would like to ask more experienced members' opinion as I am only a novice.
Straight to the issue, I could not remove the 4th wheel. For me, it seems that the bottom of the 4th wheel pivot was formerly broken but still long enough to sit in the 4th wheel bottom jewel hole. In addition, it looks that a small pipe or so was fitted from the bottom plate to the end of the 4th wheel pinion. And this is the reason that I cannot remove it.
Could it have happened as I detailed above or it is a normal thing? Should I remove it anyway and change the whole 4th wheel or the pinion if I can manage to find a replacement. What can be done? what do you suggest?
After this, I decided to carry on like that and at the end when I will measure the accuracy, it should show some really bad results in case if there is any affection.
And now got to the second issue. So, at the end of the cleaning, I found a small pin in the bottom of the horosolv jar. I managed to find its place. However, I am not quite sure how to fit it again. To be honest, I cannot see its purpose really. From the bottom end, it is underneath the setting lever, and from the top plate also it sticks out hardly any.
Have you got any idea how to solve these problems?
Sorry for the poor quality of the pictures. Hope they help though.
Please detail your answers as I am just a beginner.
Any help is much appreciated.
Gabe
P.S.: Please ignore the notes on some of the images which are not related to my issues. Thanks.
1892249721_WhatsAppImage2019-07-18at11_24_40.thumb.jpeg.00d799657ad45a91f66e4c99dd853e50.jpeg1204557455_WhatsAppImage2019-07-18at11_24_36.thumb.jpeg.10cffbbf3474363fccedf7cf4baa0058.jpeg
1782921740_InkedWhatsAppImage2019-07-18at11_23.39(2)_LI.jpg.055118501eeed87104b98feb853c1509.jpg8160902_InkedWhatsAppImage2019-07-18at11_23.15_LI.jpg.73c6d306acd2c28161a45dfdb68ced8d.jpg2140671115_WhatsAppImage2019-07-18at11_23_37.thumb.jpeg.5a0efade479384269438189ca2fac9d0.jpeg19035398_WhatsAppImage2019-07-18at11_23_15.jpeg.777ee2cdccdd2a1fd5abe12fb76e56ec.jpeg
306281800_WhatsAppImage2019-07-18at11_23.38(1).thumb.jpeg.2e6024fee41e0c7e9b1b3c6e0b20761d.jpeg1593514737_InkedInkedWhatsAppImage2019-07-18at11_23.39(3)_LI.thumb.jpg.b7f6f2115c3dfd3d7b29b3d6b4ebbcef.jpg
That little modification isn't a very good modification, it will require you to modify any pivot on the replacement wheels you buy since I guess the inner diameter of that tube isn't the same as the diameter of the original jewel hole. I  would have replaced the jewel and put a new 4th wheel in.
If the screw you arre woundering about is the one in the 3:rd picture then it is just a normal screw from the bridge, it should come ontop of where it is now when you put the trainbridge back.
Yes the loose pin is a guide pin from a bridge, but from which you have to find out your self.
I'm still pussled about that tube in the jewel, how is it supposed the lubrication comes on to the wheel pivot from the oil cup?
Edited by HSL
Swedlish
Guys,
Apologies for the late reply, I was quite busy in the last couple of weeks and not much has been done since. I designed a mainspring winder as they are quite pricy. But I stuck in a bit as I've been waiting for weeks now to get 3d printed by a friend. Until today, as finally, I persuaded my wife about 3d printers so I ordered my first entry-level machine. (Cetus mk3)
Also, I'm not sure how to deal with the worn dials. Recently, I've seen Mark's video how he printed his own dial designs. So I am going to try that way and keep the original dial in case I decide to sell the watch. First of all, I had to make a plain replacement dial with the holes and legs. The surface still needs to be polished before anything is attached.
I also checked the small minute hand. This can also prove how amateur I am in watchmaking. Delgetti, exactly as you said. Part of the minute hand stuck on the pivot of the 4th wheel so hard that I am still surprised by how I could manage to remove it without breaking the pivot.
In regard to the pin, I found its exact location, in the keyless work right underneath the setting lever. The setting lever is quite loose now even if it was not removed or loosened over the cleaning. I remember it was not wobbling at all. So, I assume that the pin adjusts the hight of the setting lever and also makes less friction as the lever comes into contact only with the top of the pin while it slides.
Any ideas how to fit it back? I can set how much it has to stick out because there are marks on the pin. But should I solder? I'm afraid of damaging other features on the plate.
I have another silly question about oiling the movement. Would it be acceptable to use 8300 natural grease where 9501 synthetic grease is advised (keyless work etc.)? In the future, I will need to buy some but now I spent way too much on this project.
Sorry for the novel.
Guys, your experience, knowledge and help are highly respected and much appreciated.
Thank you,
pin_03.jpg.df8a66ab22febedb5ccca9497ab1644d.jpgpin_01.jpeg.a8d9a5bcbb79addce42bc9392de1009e.jpegpin_02.jpeg.8e383ce1eaaba5f1eb105ece7242bb08.jpegmswinder_01.thumb.jpeg.a5ec6c4027e89fa4d30d9d1f026569b3.jpegmswinder_02.thumb.jpeg.bb2fe07e644850e393d18302eab38d9c.jpegdial_01.thumb.jpeg.2219a79a48cb1d58c837266ec45d0bc1.jpegdial_02.thumb.jpeg.bc3e4fcf77aa85ff77fe8c732c092418.jpeg
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
