ETA Resources
Just thought I should post some links here from ETA Costumer support. They are quite informative and gives you something to do on a rainy summer day.
The first one is to their Dictionary, here you can find all their definitions and even how things works, like the escapement and so on.
https://www.eta.ch/dictionary/dictionary.html
The other ones are movement specific
ETA 2892A2
https://www.eta.ch/swisslab/2892a2/2892a2.html
ETA 7750
https://www.eta.ch/swisslab/7750/7750.html
ETA 6497
https://www.eta.ch/swisslab/6497/6947.html
ETA 251.471
https://www.eta.ch/swisslab/251471/251471.html
When you go there the first time you probably need to get flash.. look up in the left corner.
After loading it is just to start exploring the information.
Edited by HSL
  • Thanks 4
  • 1 year later...
Just to avoid making too many new topics with the same subject I will post these PDF:s in this old thread.
Since flashplayer is obselete due to security lacks and not every one wants to activate it I have made some PDF:s with two of the most popular movements.
This version uses a normal PDF format which you can print out and make notes in while servicing the movement, you can brows them offline while lapping sun.
ETA 7750 Chronograph.
ETA 7750 Service Notes.pdf
ETA 6497
SwissLab_6497 Service Notes.pdf
Edited by HSL
loaded wrong file first :D
  • Thanks 2
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
