ETA Resources
Just thought I should post some links here from ETA Costumer support. They are quite informative and gives you something to do on a rainy summer day.
The first one is to their Dictionary, here you can find all their definitions and even how things works, like the escapement and so on.
https://www.eta.ch/dictionary/dictionary.html
The other ones are movement specific
ETA 2892A2
https://www.eta.ch/swisslab/2892a2/2892a2.html
ETA 7750
https://www.eta.ch/swisslab/7750/7750.html
ETA 6497
https://www.eta.ch/swisslab/6497/6947.html
ETA 251.471
https://www.eta.ch/swisslab/251471/251471.html
When you go there the first time you probably need to get flash.. look up in the left corner.
After loading it is just to start exploring the information.
Edited by HSL
  • Thanks 4
  • 1 year later...
Just to avoid making too many new topics with the same subject I will post these PDF:s in this old thread.
Since flashplayer is obselete due to security lacks and not every one wants to activate it I have made some PDF:s with two of the most popular movements.
This version uses a normal PDF format which you can print out and make notes in while servicing the movement, you can brows them offline while lapping sun.
ETA 7750 Chronograph.
ETA 7750 Service Notes.pdf
ETA 6497
SwissLab_6497 Service Notes.pdf
Edited by HSL
loaded wrong file first :D
  • Thanks 2
    • So I just wanted to say "thank you" again.  The angle is the key bit it seems and yes, it did basically just fall, or float, back into position when I got it lined up just right.
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
    • Hello Horologists, thought I'd introduce myself. I'm a 50ish year old who has been dabbling in watches for a while, did a couple of BHI course here in the UK and have started to dabble at bit more. I also took the level 1 course, which was a good refresher. Now off to look at some Bergeon tools and then buy (and regret buying) the cheaper ones...    Stirky.
    • Hi All, I thought I'd draw a diagram to help me understand the motion works for an eta 6497 so I thought I'd share it here in case anyone else finds it helpful. Any corrections, please let me know! Hope it helps. Stirky.
