smiths empire crown release problem
hi everybody  so i have just got my first watch that i have decided to strip and clean. its an old smiths empire. the watch winds up fine and runs  when placed face down. when turned over it stops. the problem i am having with it is i can't get the crown out. i have loosened the screw (too much) but the crown sten will not budge. any ideas. thankyou for your help.
Hi   Just in board from the crown there is a small screw,  The other larger screw with a blue head, is a plate screw.  Undo the small screw about two turns and release the stem. Do not unscrew it all the way or the set piece drops off  and to put it back the dial and hands have to come off. But looking at the state of the dial etc it will have to come off any way.
Hi     Looking again at the condition there is a possibility the stem is rusted in , does it turn both way  ok if so might need some penetrating substance on the stem to release it, a bit of wite spirit and oil or petrol /oil to soften the corrosion. If the screw has undone all the way might have released the set piece which has jammed the stem. If every thing fails you can always dismantle the plates. First Let down mainspring,  remove the balance , then the backplate  that will then expose the crown and castle wheels and the stem hopefuly then you will be able to get it out.  goog luck
Quote
    crown and stem:  if you now have the proper  screw and its turned l -1/2 turns.  press down on the screw,  giggle - the stem should come out.  IF NOT;  apply "penitrating oil" and come back tomorow.   vin
hi thanks for the reply. i have over screwed the small screw so i will have to take apart. the crown winds both ways very smoothly but like you said it could be rust . i will try some oil and see how i go.
cheers vin will give the oil ago.
  • 3 years later...
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
