smiths empire crown release problem
hi everybody  so i have just got my first watch that i have decided to strip and clean. its an old smiths empire. the watch winds up fine and runs  when placed face down. when turned over it stops. the problem i am having with it is i can't get the crown out. i have loosened the screw (too much) but the crown sten will not budge. any ideas. thankyou for your help.
Hi   Just in board from the crown there is a small screw,  The other larger screw with a blue head, is a plate screw.  Undo the small screw about two turns and release the stem. Do not unscrew it all the way or the set piece drops off  and to put it back the dial and hands have to come off. But looking at the state of the dial etc it will have to come off any way.
Hi     Looking again at the condition there is a possibility the stem is rusted in , does it turn both way  ok if so might need some penetrating substance on the stem to release it, a bit of wite spirit and oil or petrol /oil to soften the corrosion. If the screw has undone all the way might have released the set piece which has jammed the stem. If every thing fails you can always dismantle the plates. First Let down mainspring,  remove the balance , then the backplate  that will then expose the crown and castle wheels and the stem hopefuly then you will be able to get it out.  goog luck
Quote
    crown and stem:  if you now have the proper  screw and its turned l -1/2 turns.  press down on the screw,  giggle - the stem should come out.  IF NOT;  apply "penitrating oil" and come back tomorow.   vin
hi thanks for the reply. i have over screwed the small screw so i will have to take apart. the crown winds both ways very smoothly but like you said it could be rust . i will try some oil and see how i go.
cheers vin will give the oil ago.
  • 3 years later...
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it.
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
