Automatic oilers - what's the difference?
PeterS
Does anyone know the difference between the Bergeon automatic oilers?
They all look the same when I look at the pictures so I’m wondering if I get the 1A why couldn’t I use it for train wheel pivots and cup bearings instead of the oiler 5 if I put the appropriate oil in the 1A oiler?
One thing for sure you would need to thoroughly clean it before you put another type of oil in, which would be time-consuming and what would you clean it with to avoid damaging its seals.
Edited by TheFixer
They don't have seals in the sense of rubber o rings etc.
A plastic and metal nozzle and steel needle which is drawn back into the oil reservoir with the trigger and as you release it takes a droplet of oil with it.
The 1A has an incredibly fine tip and while you technically could oil train wheels with it, it would require a few actuations to get the desired quantity of oil to them.
The other numbers have larger nozzle and tips and if you tried to use an oil that was too thick in say the 1A it wouldn't flow through properly.
You set them to deposit the precise droplet on an end stone with one activation of the trigger.
Hour this helps.
Incidentally they really are superb for oiling shock settings and can be done in situ before fitting the balance.
Edit to say bergeon instructions for cleaning the nozzle advise to ultrasonic clean.
Edited by m1ks
Hour this helps.
Interesting thank you.
Hour this helps.
I did suspect that the nozzles would be different sizes but I couldn’t tell from looking at the images.
It all makes sense now!
Could anyone give me some more details about the 2A? I can see that the 1A could be very useful, probably the 5 as well but I can’t see much use for the 2A oiler, perhaps a precise amount of 9415 (or other pallet grease) on the pallet stone and that’s it?
I can only advise on the 1A as I just have that one and know the others are larger.
The 'trigger' is on an eccentric screw so with a combination of that and how far you insert the needle and lock it in place you can vary the amount from a tiny droplet to a reasonable size droplet.
I'd think the 1A would be more suitable for oiling pallets but honestly I couldn't justify the cost of more than one when standard oilers are good enough, if I were doing it as a career and serviced a large quantity or a lot of the same I'd consider a second one.
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
