Automatic oilers - what's the difference?
PeterS
Does anyone know the difference between the Bergeon automatic oilers?
They all look the same when I look at the pictures so I’m wondering if I get the 1A why couldn’t I use it for train wheel pivots and cup bearings instead of the oiler 5 if I put the appropriate oil in the 1A oiler?
One thing for sure you would need to thoroughly clean it before you put another type of oil in, which would be time-consuming and what would you clean it with to avoid damaging its seals.
Edited by TheFixer
They don't have seals in the sense of rubber o rings etc.
A plastic and metal nozzle and steel needle which is drawn back into the oil reservoir with the trigger and as you release it takes a droplet of oil with it.
The 1A has an incredibly fine tip and while you technically could oil train wheels with it, it would require a few actuations to get the desired quantity of oil to them.
The other numbers have larger nozzle and tips and if you tried to use an oil that was too thick in say the 1A it wouldn't flow through properly.
You set them to deposit the precise droplet on an end stone with one activation of the trigger.
Hour this helps.
Incidentally they really are superb for oiling shock settings and can be done in situ before fitting the balance.
Edit to say bergeon instructions for cleaning the nozzle advise to ultrasonic clean.
Edited by m1ks
Hour this helps.
Interesting thank you.
Hour this helps.
I did suspect that the nozzles would be different sizes but I couldn’t tell from looking at the images.
It all makes sense now!
Could anyone give me some more details about the 2A? I can see that the 1A could be very useful, probably the 5 as well but I can’t see much use for the 2A oiler, perhaps a precise amount of 9415 (or other pallet grease) on the pallet stone and that’s it?
I can only advise on the 1A as I just have that one and know the others are larger.
The 'trigger' is on an eccentric screw so with a combination of that and how far you insert the needle and lock it in place you can vary the amount from a tiny droplet to a reasonable size droplet.
I'd think the 1A would be more suitable for oiling pallets but honestly I couldn't justify the cost of more than one when standard oilers are good enough, if I were doing it as a career and serviced a large quantity or a lot of the same I'd consider a second one.
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
